My new Stance = Bilstein +3 R / +5 F
Old Sep 1, 2009 | 05:16 AM
  #41
vispre's Avatar
vispre
Originally Posted by gennosuke1
id change back to stock taillights
look like stock tails to me
unless he pulled a fast one and installed some new ones within the past month or so.
Old Sep 1, 2009 | 08:23 AM
  #42
cliffrlp's Avatar
cliffrlp
Yep they're stock w blues bats overlays.
Yep v2
Old Sep 1, 2009 | 08:50 AM
  #43
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
Looks great! If do run Auto-X/Track days the height in the back won't rub with compression. Otherwise, lowering it more without a fender roll will rub.
I have that same lip, but a replica, and I sit that low-up front as well. I hit pine cones in my office parking lot all the time...lol
Actually, had to add curb rubber ramps to get in my driveway.
http://www.mccarthysteel.com/product...1_lbs_ea..html
Old Sep 1, 2009 | 08:52 AM
  #44
Gsedan35's Avatar
Gsedan35
Originally Posted by guitman32
Also, after riding in your car with these, I'm definitely picking up a set. I think you should consider deleting the rear progressive spring with a linear replacement. That will put you in a better place when you get into autocrossing and DEs, and also let you take the rear a bit lower when you're having late night gorilla stance cravings.
I just need to design and fabricate a spring adapter for the lower spring seat. Edit: Or you could go with the SPL pieces, though I think fabricating an adapter will be just as effective and much more wallet friendly.
Been their done that
https://my350z.com/forum/brakes-and-...ver-kit-2.html
^ post 21 & 23
DO NOT take the car lower! You don't want to drop the pss(9/10) too much, they hardly have any bump travel at a 1" drop.
Old Sep 1, 2009 | 03:34 PM
  #45
guitman32's Avatar
guitman32
Gsedan35, thanks a bunch I really appreciate the pictures. Saved me some time for sure I have a few questions:
1. Does the adapter plate on the revised seat thread onto the collar like the locking nuts?
2. What material did you use to insulate the spring from the adapter plate? I was thinking of using some of the delrin I have laying around, but from the looks of your design the insulator serves to keep the spring centered on the perch, necessitating the use of a softer material than delrin.
3. Do you have any recommendations on spring length given the OPs requirement of having the ability to go slightly lower than he is now, while still being able to raise it back to a streetable/trackable height if necessary? From your post in the other thread, you're using Eibach ESS springs, 9.5" tall. I'm just not sure what this equates to in terms of height range.
4. Any thoughts on spring rate given he is running stock valving?
Your advice on riding the bump stops is duly noted. The OP and myself have experience with this first hand at the height in the pictures.
Leor I hope I'm not giving away any secrets , but we raised the car after checking the lowest height range of the shocks (as pictured). Even then, we hit the front bump stops with two passengers - only once, but still a concern nonetheless.
Old Sep 1, 2009 | 04:47 PM
  #46
Gsedan35's Avatar
Gsedan35
Your welcome.
1. The adaptor isn't threaded, I milled it to be a snug slip fit on the Bilstein seat collar. 6061 is relatively strong, but I would not trust a threaded adaptor.
2. I came up with a really simple solution. I had to have something that would add protection against the spring walking and it add's a smidge of isolation. It's a modified silicon rubber sink stopper purchased down the faucet isle of any Home Depot. The stopper happens to be a perfect 5" OD and I just cut the center out, leaving a 1/2" wide ring that serves my purpose perfectly.
3. Use a 400-425 lbs spring, do not attempt to go any higher. IIRC set to max height= a 7/8" drop. Going out and measuring the adjustor, you should be able to drop down another .4"
Old Sep 1, 2009 | 04:53 PM
  #47
haeshik's Avatar
haeshik
love the stance and color combo
Old Sep 2, 2009 | 12:34 AM
  #48
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
How in the world do you drive around like that is beyond me! lol looks sexy! Just too low for me!
Old Sep 2, 2009 | 08:15 AM
  #49
guitman32's Avatar
guitman32
Originally Posted by Gsedan35
Your welcome.
2. I came up with a really simple solution. I had to have something that would add protection against the spring walking and it add's a smidge of isolation. It's a modified silicon rubber sink stopper purchased down the faucet isle of any Home Depot. The stopper happens to be a perfect 5" OD and I just just the center out, leaving a 1/2" wide ring that serves my purpose perfectly.
Thanks again, and really great tip in the sink stopper! We will be sure to send you pictures and impressions once we're finished with the process.
Old Sep 2, 2009 | 08:32 AM
  #50
dcash5's Avatar
dcash5
Once again i'd be really interested in the outcome of this aswell.
Dan
Old Sep 2, 2009 | 09:21 AM
  #51
vthao's Avatar
vthao
Looks good mane
Old Sep 2, 2009 | 09:48 AM
  #52
350Zdj's Avatar
350Zdj
awesome! never was a big fan of xd9's but this set up just changed my mind.
Old Sep 2, 2009 | 10:29 AM
  #53
Gsedan35's Avatar
Gsedan35
Dan
Dan it works great, I only post things like that once they have been thoughly tested. Absolutely zero issues. You do have to be more carefull on install, but other then a little more time, that's it. Going to the linear springs vs progressive gave the car better turn in and more predictable at the limit behavior.
Old Sep 2, 2009 | 10:45 PM
  #54
cliffrlp's Avatar
cliffrlp
Gsedan35 thanks for the comments! It's great when conversation like this happens on the forums...
I will be placing my order soon and will hopefully be up and runnin in Oct. So Guitman32 be ready for another weekend of work and party!
Everyone else, thanks for the kind words!
Alyvin...I raised the front 1/2"...my 255s were rubbing like no buddies business lol
Old Sep 3, 2009 | 06:19 AM
  #55
vispre's Avatar
vispre
Old Sep 3, 2009 | 07:37 AM
  #56
cliffrlp's Avatar
cliffrlp
lol i wanted to get back from miami w/ my bumper somewhat in tact...don't judge!
Old Sep 3, 2009 | 09:05 AM
  #57
guitman32's Avatar
guitman32
Don't forget that once you add front camber arms and dial out some of the front camber it will change the stance slightly.
Old Sep 3, 2009 | 01:25 PM
  #58
cliffrlp's Avatar
cliffrlp
very true. need to order those and the rear springs...
Old Sep 3, 2009 | 08:32 PM
  #59
cliffrlp's Avatar
cliffrlp
gsedan35 I pmed you
Old Sep 4, 2009 | 04:40 AM
  #60
350Zenophile's Avatar
350Zenophile
Ride looks great OP! I just had PSS9s installed yesterday and I can say these things ride amazing.
We also removed the upper lock nut in the rear to even it out...when you guys say you are hitting the bump stops, is it in the rear or just the front?
