Question: 350Z stock hub and rotor?
Old Oct 8, 2009 | 05:01 PM
Kuhan's Avatar
Kuhan
Default Question: 350Z stock hub and rotor?
Hello,
I just got a set of used Rays Roja R2-5 wheels
Spec
Wheel Size: 19x9.5 / 19x10.5
Wheel Offset: +25 / +19
wrapped in pirelli PZero
255/35/19
275/35/19
I got the wheels mounted today. The wheels look nice, but the rears are sticking about 1/2 in. out (from fender) since it's 19x10.5 w/ 19mm offset, which I don't like. I want the rear wheels to be flushed with the fender.
Is there a way for me to make it flush?
This might be a stupid question, but are there any aftermarket hubs that are smaller in thickness comparing to stock hubs? I want like 1/2 in. smaller than the stock hubs.
Similar to the blue hub on the picture below. Thanks.
Old Oct 8, 2009 | 05:20 PM
Coffeemaster's Avatar
Coffeemaster
Roll your fenders and pull them.
Old Oct 8, 2009 | 07:41 PM
No. You can move the wheel closer to the fender. You cannot move the wheel closer to the suspension components.
With the OEM calliper, brake rotor position is fixed. The hat of a 2-piece rotor may look different, but the rotor is in the same position. Remember that the rotor must fit inside the calliper. And the position of the calliper is fixed.
Old Oct 8, 2009 | 07:45 PM
T_K's Avatar
T_K
Originally Posted by Kuhan
That's a brake hat.
This is a wheel hub.
Old Oct 9, 2009 | 08:19 AM
terrasmak's Avatar
Just add a little more neg camber. Are you lowered? if not , just lower it a little and the wheels will pull in.
_koubie_
Sep 20, 2015 06:34 PM
