Should I lubricate sway bar bushings?
Old Oct 14, 2003 | 04:34 PM
DMONTE's Avatar
DMONTE
Question Should I lubricate sway bar bushings?
I just purchased a set of nismo sway bars, I am wondering if I should lubricate the bushings when I installed them. And if so with Watt lubricant?
Thanks
DMonte
Old Oct 14, 2003 | 06:52 PM
FLY BY Z's Avatar
FLY BY Z
I didn't. No need. No squeaks. Will let you know if it starts though.
Old Oct 14, 2003 | 07:38 PM
MY350Z.COM's Avatar
not necessary but i did mine just in case, i think it prevents squeaking.
Old Oct 15, 2003 | 05:29 AM
Audito350Z's Avatar
Audito350Z
Lube them if they came with new poly bushings... they will squeek. If they use the OEM rubber bushings, then you probably don't need to lube them.
Use any water repellant lube or grease.
Also, the lube eventually dries out and wears away... you may need to lube once a year.
PeteH
Old Oct 15, 2003 | 08:52 AM
John's Avatar
John
With poly bushings, I've found that I need to relube them every two months to avoid the squeaking... perhaps I should try something other than white lithium grease...
Old Oct 15, 2003 | 03:17 PM
FLY BY Z's Avatar
FLY BY Z
If I remember correctly they use rubber not poly.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
