adjustable upper control arm
Old Mar 13, 2010 | 07:53 PM
whoisthis's Avatar
whoisthis
Default adjustable upper control arm
i need to fix my bad alignment so i took this to a shop n measured the alignment. camber is -.9 and also caster and toe is off the factory spec. since i cant afford both caster/camber adjuster, im thinking of just getting camber kit. is this ok? i currently hav no inner tread for both front tires. also my rear camber has -1.0 should i fix.both front and rear together or is it ok if i fix front first? thx guys
Old Mar 13, 2010 | 10:47 PM
terrasmak's Avatar
I would start reading in the suspension forum, just be carefull, you may learn something without being spoonfed.
Old Mar 14, 2010 | 07:23 AM
I know nothing about your car. OEM suspension? Lowered? Big wheels and tires?
Old Mar 15, 2010 | 08:52 PM
Thermal1's Avatar
Thermal1
1) all the info you seek is already in this forum.
2) you didnt even give enough info for anyone to answer your question.
The generic answer is: buy a rear camber kit (SPC or Eibach). It is inexpensive and includes toe bolts. Toe eats tires. Camber - not as much.
front camber arms are more expensive and often are not necessary. A shop can typically get the front in spec with the factory adjustments.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
