I feel like I'm getting robbed. $750 install??
Old Apr 13, 2010 | 08:49 PM
  #41
terrasmak's Avatar
Glad to hear your doing it yourself, built, not bought is so much cooler.
Old Apr 14, 2010 | 09:27 AM
  #42
Z_flip's Avatar
Z_flip
I got my coilovers installed for about 100$ here in socal... signal auto. Too bad they're gone though =[
Old Apr 14, 2010 | 12:26 PM
  #43
quakerroatmeal's Avatar
quakerroatmeal
Go to your region area and see if there's someone within your area that could do it for you for a better price is another option as well.
Old Apr 14, 2010 | 02:40 PM
  #44
MDHRZ's Avatar
MDHRZ
...or ask gregtotheb to show you around since he knows everybody. He wouldn't pay over $300.
Old Apr 14, 2010 | 02:57 PM
  #45
Goo$e's Avatar
Goo$e
OP, I did my own HKS Hypermax III install myself. It was a fun project. It look me a while to complete the work because I never did it before. I bought the tools and I believe it was $100 or less for everything (unless you need a jack/jackstands). Only downside is once you get that stuff installed you need to take it to a shop and get an alignment.
I dunno. Maybe somewhere between 500-750. Does this $750 install include alignment? If it does, that's a really good deal imo.
Old Apr 14, 2010 | 03:06 PM
  #46
gregtotheb's Avatar
gregtotheb
ahh the fanboy resurfaces.
Old Apr 14, 2010 | 03:31 PM
  #47
scotts300's Avatar
scotts300
Keep it on topic, or infractions will be given.
Old Apr 14, 2010 | 03:33 PM
  #48
gregtotheb's Avatar
gregtotheb
Never left. Fanboy? lol.
yep!
Old Apr 14, 2010 | 03:34 PM
  #49
gregtotheb's Avatar
gregtotheb
got it!
Old Apr 14, 2010 | 04:01 PM
  #50
gregtotheb's Avatar
gregtotheb
good luck with the DIY! post pics when you're done! little guy? not as little as your ninja250 lol.
Old Apr 14, 2010 | 04:14 PM
  #51
CRIDDA's Avatar
CRIDDA
OP, ask @ your regions area and see if someone would mind lending you a hand. Here in GA, we look out for our brothers and are always there to help. It might cost you a 12 pack, but you will meet some cool cats and gain alot of knowledge. GL bro
Old Apr 14, 2010 | 04:40 PM
  #52
pony_killer's Avatar
pony_killer
Arada ninda apa
either DIY or don't pay over $400 for everything. I got all my work done last year for around $300 + alignment
Old Apr 14, 2010 | 04:56 PM
  #53
gregtotheb's Avatar
gregtotheb
Not ashamed of the 250R as a first bike . Yes, you are a little guy based on your MySpace pictures .
if you say so.
Old Apr 14, 2010 | 05:46 PM
  #54
sfearl1's Avatar
sfearl1
not to hijack but my question is along the same lines guys ... i was quoted $525 minimum for a simple set of springs and sway bars installation. i'm thinking that sounds ridiculously high. i installed a Motordyne MREV2 and plenum spacer 2-3 weeks ago without any problems whatsoever... is this also something i'd be able to do myself with the proper tools and ample amount of time?
Old Apr 14, 2010 | 05:47 PM
  #55
MDHRZ's Avatar
MDHRZ
https://my350z.com/forum/brakes-and-...ts-needed.html
Old Apr 14, 2010 | 05:52 PM
  #56
sfearl1's Avatar
sfearl1
thx
how do you feel about the $525 quote i was given? high? they also quoted something like $300-400 for the plenum work which wasn't hard or time consuming at all. i'm no tim the toolman taylor but i can certainly find my way around the garage if it'll save me $500!
Old Apr 14, 2010 | 06:25 PM
  #57
bimmertech's Avatar
bimmertech
i do a fair amount of side work, and go with book labor times(although there are no book times for setting ride height on a set of coilovers, or most other aftermarket parts) at $40/hr.
at that rate, i would charge around $3-400 for the work quoted. so for a shop to charge $750 is not that out of wack considering the door rate of most shops are double my rate.
its always cheaper to diy, unless you screw something up and have to have a shop fix it.
Old Apr 14, 2010 | 08:17 PM
  #58
terrasmak's Avatar
I would charge about $225 , but most car work I comsider hobby and not work.
Old Apr 21, 2010 | 06:50 AM
  #59
R350Zz33's Avatar
R350Zz33
Originally Posted by 350junkie
glad to hear you're gonna do it yourself. Might want to add a 14mm end wrench to that list. I also don't know what you guys are talking about with these extensions either. I've dropped the exhaust/cats from the car in under 30 minutes. The cats really aren't that big of a deal. Just unbolt the Y-pipe from the rest of the exhaust to give you some extra play to get the cats unhooked and out.
and remember... patience is a virtue, and you'll probably skin a knuckle or three
extensions to unbolt the cats from the header from the top the front of the car just gotta remove intakes though
Old Apr 21, 2010 | 07:36 AM
  #60
tylerxfire's Avatar
tylerxfire
^^the cats dont need to be messed with from the top..i unbolt mine and do them from the bottom...all the bolts
