Can I change a front sway on ramps?
Old May 15, 2010 | 07:24 AM
confusa's Avatar
confusa
Default Can I change a front sway on ramps?
Just want to confirm that having weight on the front wheels and suspension will not hamper my efforts. I am unsure if there will be any pressure that will either spring the bar off and decapitate me or make it impossible to put the new bar back on.
Old May 15, 2010 | 08:05 AM
350junkie's Avatar
350junkie
all the bar does is keep the suspension linked together. Unless you're trying to change it while taking a turn at 90 MPH there isn't any risk of that.
My question is, you can get your Z onto ramps?
Old May 15, 2010 | 09:05 AM
DavesZ#3's Avatar
DavesZ#3
Yes, it's simple to change either front or rear on ramps.
I remove the nuts from the lower control arm end of the endlinks then disconnect the brackets that hold the swaybar in place. That keeps it suspended under the car so it doesn't crash down on your head. Then I work the endlink stud out of the LCA and lower it the rest of the way to the ground. Install in reverse order.
Old May 15, 2010 | 09:44 AM
confusa's Avatar
confusa
The low profile Rhino ramps will work on my stock height Z.
Old May 15, 2010 | 12:16 PM
12AutoX's Avatar
12AutoX
As long as both wheels are at the same suspension load it is easy. If you try to jack up the car on one side at a time , the bolts won't line up. It's a little tough working around the tires, too if you are using ramps.
Old May 16, 2010 | 07:35 AM
DavesZ#3's Avatar
DavesZ#3
I've never removed wheels just to work on sways. Not sure why they would be in the way.
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 25, 2021 06:26 AM
Stevo Z
Oct 3, 2015 09:14 PM
