OEM rear spring basket (adjustable camber) where can I buy this??
Old Aug 14, 2010 | 07:36 AM
RandyK1's Avatar
RandyK1
Default OEM rear spring basket (adjustable camber) where can I buy this??
I have some new coilovers ordered that use an OEM type rear spring. Where can I find a camber adjustable spring bucket for my 06 Z? I saw them somewhere before but I searched and couldnt find them again. Thanks
Old Aug 14, 2010 | 08:12 AM
fakejojo's Avatar
fakejojo
SPL Suspension has the Adjustable Spring bucket
However, the spring bucket can only accomodatge 2.5inch ID springs, which are rare in coilovers and thus the rear spring needs to be ordered by a company that specializes in 2.5inch ID springs
Old Aug 14, 2010 | 01:56 PM
bimmertech's Avatar
bimmertech
the "spring bucket" or "midlink" controls toe, not camber.
splparts.com
Old Aug 14, 2010 | 05:09 PM
RandyK1's Avatar
RandyK1
O.K. Toe (sorry) I am getting Tanabe Sustec Pro S-OC Coilovers, so I need spring buckets that will fit these springs. I saw different ones somewhere and I cant remember where.
Old Aug 14, 2010 | 07:05 PM
bimmertech's Avatar
bimmertech
the spl midlinks(the only aftermarket spring arm i am aware of), like stated, use a 65mm spring. just buy spme swift springs in the rate you want when you buy the midlinks--spl sells them. you will also want a set of eccentric lockouts--spl also sells those.
the spl midlinks have a built in height adjuster, so you will not need any of the rear spring stuff that comes with the tanabe's.
the end will look like this(note the black arm with peach colored spring--eccentric lockout on subframe side of arm):
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
CJs_Z33
Sep 18, 2015 12:06 PM
