Rear is uneven..
Old Sep 20, 2010 | 01:15 PM
sleeperZ69's Avatar
sleeperZ69
Default Rear is uneven..
So I've been reading around on this and other forums, and found that others have had the same problem. I'm on stock suspension, but I just got some new 285/35/19 rear tires put in, and only my drivers side rubs on bumps and dips.
I measured the gaps between the fender and wheel, and it is lower on the drivers side. A lot of others have noticed this both on stock and after market suspensions. One recommendation is that I rotate my rear springs. Has anyone on here done this? If so, how possible is it to do myself?
Thanks
Old Sep 20, 2010 | 01:42 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
then it will still be uneven, just the reverse
the car does not weigh the same left to right....the only real way to ensure it is perfectly even is via coilovers
Old Sep 28, 2010 | 07:03 PM
omsin523's Avatar
omsin523
Wouldnt the added weight of the driver also play a role in rubbing?
