hotchkis rear swaybar adjustment
Old Nov 15, 2010 | 02:12 PM
nismospec's Avatar
nismospec
Default hotchkis rear swaybar adjustment
ok, not the greatest with tools, i'll admit it.
so as far as adjusting the rear swaybar, do you have to remove the clips where you apply the grease to adjust, or do you just have to unbolt the endlink portion, change holes, and bolt on the endlink again?
basically, if you jack the car up on stands, should you be able to adjust the rear sway, or do you have to remove the rear wheel?
Old Nov 15, 2010 | 02:28 PM
DavesZ#3's Avatar
DavesZ#3
Disconnect endlinks then reconnect in now position.
Yes, you can do it from jackstands or ramps. No need to take the wheels off.
