exhuast with gt spec bracing
Old Nov 29, 2010 | 12:28 AM
jerryd87's Avatar
jerryd87
Default exhuast with gt spec bracing
trying to plan my build out, getting ready to deploy in a few months and wanted to get parts sorted out before i left so my wife can order them when it gets close to time to get back. planning on doing a boosted performance single turbo kit but i read the gt spec bracing has issues with 3 inch exhaust. question is, do they have a version for use with 3 inch(i couldnt find one) or is there a dual exhaust that would work well with the bracing and the turbo kit? what parts of the gt spec "kit" so to speak interfear with the exhuast and should i just leave these out? car will be mostly autox with a bit of drag racing thrown in and alot of street driving. sorry if this is the wrong section i figured it was a mix of several topics lol
Old Nov 29, 2010 | 02:27 AM
calin's Avatar
calin
The GTSPEC bars do not have anything to do with the exhaust piping size. And they will fit on your car no matter which exhaust you have.
Old Nov 29, 2010 | 05:09 AM
R350Zz33's Avatar
R350Zz33
are you sure i remember one exhaust that was in the way and dident work with it
Old Nov 29, 2010 | 05:15 AM
BoomerZ33's Avatar
BoomerZ33
i know the rear lower tie bar won't clear a 3 inch Fast Intentions exhaust. tried to put it on a friend's car it wouldn't fit
Old Nov 29, 2010 | 07:02 AM
Kwame's Avatar
Kwame
The Rear Lateral Arm is the only piece that has fitment conflicts with some exhausts.
Old Dec 12, 2010 | 02:17 PM
f-350z's Avatar
f-350z
while Greddy evo TT was on, that piece cleared the exhaust, after replace my exhaust with greddy Ti-C (2.75'' true dual turbo exhaust) it didnt clear and was touching the flange between the mid-pipe and muffler (the driver side only)
so i just took it off
Old Dec 12, 2010 | 02:31 PM
terrasmak's Avatar
Very easy solution, ditch the GT spec bar idea. They are not needed, if you get to the point they are needed, you should be installing a cage.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
