Konis are on!
Old Nov 21, 2003 | 10:52 AM
dwnshift's Avatar
dwnshift
Default Konis are on!
I have only driven the car for about 10 minutes so far and first impressions are ............
Soooooo much better.
Old Nov 21, 2003 | 11:08 AM
jmark's Avatar
jmark
Yes! Give us a full report as soon as you can! How's the bounce?
Old Nov 21, 2003 | 11:15 AM
Xeinth's Avatar
Xeinth
Is this your street car?
X
Old Nov 21, 2003 | 11:47 AM
dwnshift's Avatar
dwnshift
Yes these are the same Konis that will be avaialbe in the spring. I will be able to give more feedback after I drive the car around this weekend.
The car right now is on rails with the 350EVO sway bars!
great combo for the street!
Old Nov 21, 2003 | 12:02 PM
Boomer's Avatar
Boomer
BJ, we are ready for your analysis. I can't imagine being more ready. Your perspective is invaluable to me and many others. Thank you.
Old Nov 21, 2003 | 12:04 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
1. How did you get it so early?
2. Is this the Koni Adjustable Shock? (The Orange One?)
3. Is it installed with stock springs or aftermarket springs?
4. What is the expected price for a set (front & back)?
Thanks for your time!
Old Nov 21, 2003 | 12:16 PM
jmark's Avatar
jmark
BJ is a trained professional and they want his expert opinion that's why. These are the SA Yellow Sports we all want. BJ is running a Track with stock springs and rims. Sounds like the solution for me BJ. Where do I sign up????? Is the bounce gone????? Sounds like 350Evo needs to come up with a 350Evo sways/Koni package deal. What do you think BJ?
Old Nov 21, 2003 | 12:39 PM
dwnshift's Avatar
dwnshift
I believe we will be carrying BBS wheels for the 350Z very soon.
Old Nov 21, 2003 | 02:22 PM
dwnshift's Avatar
dwnshift
OK drive home......
Very stable....I havent checked to see were they are set on the rebound settings front and rear yet. I will check over the weekend and play with them a little.
The setup right now is so much more tolerable vs the OEM setup.
The car is very forgiving over harsh bumps without being too abrupt.
The rebound in the rear REALLY has helped the bouncing that made me sick on the way too and from work.
Next week we plan putting on some new springs with these puppies but for now I will continue to play around.
The feeling of the slammed Civic with cut springs is gone........now there is proper control of the shock. I believe this set up is going to make a lot of people very happy as a daily driver set up and your average track use.
Its gotta be those 350EVO adjustable sway bars!!!!!!!
Old Nov 21, 2003 | 02:59 PM
Boomer's Avatar
Boomer
OK drive home......
HAHA! Good plug, BJ. Your words are music to my ears. Exactly what I wanted and hoped for by Koni. They work with the stock springs, just as Gordon said they would! My titanium butt is overjoyed, now GIMMIE! A set of those 350EVO adjustable swaybars may go on after I 've had a chance to savor a decent ride, who knows? Thanks for the continuing impressions, BJ.
Old Nov 21, 2003 | 06:25 PM
jmark's Avatar
jmark
BJ,
Thanks! Sounds like the Koni's have answered the one big problem I have had with this car since day one the BOUNCE! Is the 4 mile stretch to & from work OK now? Continue to give us your impressions as you get time documentating the shock settings if you can. Are the shocks easily adjusted both front & rear?
Old Nov 21, 2003 | 09:45 PM
EnthuZ's Avatar
EnthuZ
Are they available in colors other than yellow? J/K
What is adjustable....bump or rebound? How are they adjusted? Is the front bump softened?
From what I've read......I'm thinking of just the rears for me as I do not want a setting softer than OEM front bump for my track days.
Off topic......How is your brake cooling kit coming along?
Old Nov 22, 2003 | 03:11 AM
jmark's Avatar
jmark
Rebound adjustable only.
Old Nov 22, 2003 | 02:08 PM
jmark's Avatar
jmark
BJ,
Do you know what the settings are on the shocks right now?
Old Nov 22, 2003 | 02:21 PM
dwnshift's Avatar
dwnshift
Have no idea where they are at right now. I will check tomorrow. As far as front bump goes........these dont feel to much different from the oem shocks ....i would just say the control is much better.
These are part of the equation....changing the rubber oem bushings is the other part.
The oem valving couldnt control the "wind up" associated with the OEM rubber bushings....ecsp on the rear upper control arms. You will notice a huge difference in just changing those alone......even on the front of the car.
hmmmmmmm .........now where can one get rear upper control arms bushings???? Hmmmmmmm?
ll
ll
ll
ll
V
Old Nov 22, 2003 | 07:29 PM
dwnshift's Avatar
dwnshift
Wind up in the rear bushings for those that are asking.......
Here is something to try to show the wind up in the 350Z's rear upper control arms.
If you disconnect the rear ball joint on the upper control arm from the hub.........lift up on the control arm.......then let it fling....watch out.
Basically its exactly what it sounds like. It is how the oem rubber bushing is clamped and the amount of energy that is built up in the bushings.......
I am sure someone can really explain this alot better.
Old Nov 23, 2003 | 02:30 AM
TCL's Avatar
TCL
BJ, are you saying that the Konis are only effective with the bushings and that they are not part of the Koni kit?
Old Nov 23, 2003 | 04:35 AM
jmark's Avatar
jmark
BJ do you have these bushings on your street Track right now while testing the Konis?
Old Nov 23, 2003 | 05:15 AM
dwnshift's Avatar
dwnshift
I do not have the bushings on right now. We have all ready tested them in another set of control arms.I have the OEM rubber bushings still in the car. Removing the OEM bushings will let the shocks work even btter now that there is real control.
We make our own control arm bushings ......they do not coem with the Koni kit.
Old Nov 23, 2003 | 07:30 AM
MY350Z.COM's Avatar
got any pics of the bushings?
i don't see them listed on the website.
