How to tighten Rear 5 way adjustable shocks?
Old Feb 3, 2011 | 11:26 AM
raiyan84's Avatar
raiyan84
Default How to tighten Rear 5 way adjustable shocks?
Ive been rubbing alot after putting my spacers even after i rolled the fenders. so i decided it was worth it just to tighten the suspension, i have 5-way adjustable shocks and the front ones were easy to find sitting right under the hood. Im having some trouble finding the ones in the rear if anyone knows where they are and maybe has a diagram or something it would be very helpful
Old Feb 3, 2011 | 11:31 AM
06blueZ's Avatar
06blueZ
might be a good idea to share what kind of shocks you have...
Old Feb 3, 2011 | 11:47 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Bet he has to take them out cause the adjustments are at the top USUALLY...
+1 on what shocks you have OP..
Old Feb 3, 2011 | 01:03 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Shock stiffness ≠ spring travel.
Old Feb 10, 2011 | 02:28 PM
TheMambanator24's Avatar
TheMambanator24
OP, search is your friend. The easiest way to adjust them is to open up the plastic rear strut bar and drill a hole there to access the top of the shocks. It's been done many times before and you can easily find a thread that walks you through it. Otherwise, you'll have to take the whole shock out and adjust it from there.
AdvanZ33, my rear tires are rubbing as well and initially I thought the solution would be to stiffen up my rear suspension. I'm running a springs + adjustable shocks setup, so are you saying that shock stiffening won't really help me out? Will I need to purchase stiffer springs?
Rowlett
Misc.
Oct 2, 2015 10:38 AM
