alignment needed?!?!?!!!
Old Mar 27, 2011 | 05:53 AM
tw8715's Avatar
tw8715
Default alignment needed?!?!?!!!
was wondering if i remove this brace and reinstall it.. do i need an alighmnet??
since the brace is connected to the compression rods.
Old Mar 27, 2011 | 09:59 AM
gregom's Avatar
gregom
It's not directly connected to the compression arms, you'll be fine. Only thing I can tell you though is the bolts on mine were very, very hard to get off. I ended up having to use one of those wrenches with the joint and long handle, place a jack under the wrench and apply pressure upwards so there was some of the weight of the car on it. Otherwise the metal on these bolts was soft and tear.
Good luck... you don't need an alignment after the removal/reinstallation.
Old Mar 27, 2011 | 02:59 PM
terrasmak's Avatar
Nope, no alignment needed.
Old Mar 27, 2011 | 04:42 PM
tw8715's Avatar
tw8715
Thanks!
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
