flush with camber kit?
Old Nov 16, 2011 | 05:44 PM
hunterclowdus's Avatar
hunterclowdus
Originally Posted by Czarrr
Excuse me if i'm not getting my words out correctly.
I might be confusing myself, but...
Let me get this straight, you want the top of the wheel to be out more?
Less of an angle? Add more camber.
It'll bring the bottom closer to the car and the top closer toward the fender.
The spacer will just pull the wheel out more.
The negative camber will stay, but the top of the wheel will be closer to the fender.
The closer you want to get to the fender, the more likely you'll need to roll the rear fenders.
I want my rear wheels as flush with the fender as possible with as little camber as I can run...make since? to achieve this do I need spacers? camber kit? or both? and I plan on rolling my fenders because from what I have read, it is the only way to get flush as possible
Old Nov 16, 2011 | 09:09 PM
shaddy-z.'s Avatar
shaddy-z.
Get a 20 mm spacer.. I'm running almost the same setup as you but I have 18x10.5 +15 all the way around with 245/40. In the rear I'm running a 20 mm spacer which brings my offset to a -5. But I have smaller tires, and am running -3.8 camber (this is while maxed out on coils) if you would like me to take a picture of my "flushness" I can.
Does anybody want to let me know if it's normal to run -4.2 degrees of camber on stock arms in the fronts? They look kind of tucked it but that could be to the fact I pulled my fronts but I don't know.
Most recent picture -
Old Nov 16, 2011 | 11:36 PM
Czarrr's Avatar
Czarrr
Nevermind on the spacers.
Just add more camber.
You can definitely pull off in spec camber in the rear with the current set up you have.
Old Nov 17, 2011 | 12:10 AM
terrasmak's Avatar
You will probably need both. First you will need to get camber arms and toe bolts. Install them and align the car. Tell the alignment tech that you want your camber set to -1.1ish. Once the alignment is complete you can now look and see if you need to install spacers.
What are the specs of the wheels ? What size tires? I would expect you may need a 10mm to 15mm spacer depending on your liking when it is all said and done.
Remove camber, adding camber would pull the tops of the tires further into the the wheel well.
Old Nov 17, 2011 | 05:13 AM
hunterclowdus
the wheels are 18x10.5 +20 all around
the tires are 265/40/18 all around
I am going to order a rear camber kit and roll my fenders then measure see what I want. thanks to everyone that helped me out you guys really do influence the young guys like myself
Old Nov 17, 2011 | 05:47 AM
terrasmak's Avatar
18x10.5 +20 is close to flush fitting, probably perfectly flush with OEM camber specs. You will probably end up wanting a 5 to 10 mm spacer when finished.
I run at 18x10.5 +10 with a 275/40-18 and the wheel sticks out 10mm from the fender at -2.2 camber.
Old Nov 17, 2011 | 12:39 PM
Czarrr's Avatar
Czarrr
I meant add more camber as in... less negative?
Dang I sound retarded.
-2 degrees -> -1degree
Old Apr 20, 2014 | 08:58 PM
DissFoo's Avatar
DissFoo
Message moved
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
