G35 springs on a 350z?
Old Feb 1, 2012 | 03:15 PM
supraturboman's Avatar
supraturboman
Default G35 springs on a 350z?
This may be a stupid question, however I am very new to the 350z world.
But I have a possible great deal on a set of new Tein springs. But they are for a G35 coupe.
So simply put, will these work for me?
Mine is a 03' enthusiast?
Old Feb 1, 2012 | 03:17 PM
Kirbaaybaayy's Avatar
Kirbaaybaayy
yes they will
Old Feb 1, 2012 | 03:46 PM
Waiz's Avatar
Waiz
If you would have searched for "G35 Springs" by "Title" you would have seen that the springs are not meant to be swapped from a G35 due to the raised stock height of the G35 in comparison to the 350z, it would not be a good match.
I would pass on this deal and get something from our marketplace that was meant for a 350z instead
Vendor marketplace:
https://my350z.com/forum/suspension-415/
Private Marketplace:
https://my350z.com/forum/suspension-412/
Old Feb 1, 2012 | 03:52 PM
kevincat's Avatar
kevincat
i had a set of g35 teins stech on my z for a few months before i went to coilovers, so yes it will fit no problem.
Old Feb 1, 2012 | 04:32 PM
supraturboman
Im sorry for not using the search function. On my blackberry it makes it a little tricky to navigate through the forum... But thank you for the input. What would you guys recomend for springs? I am not racing the car at all. I am wanting to go low on my staggered 18's. Meaning minimal wheel gap...
Old Feb 1, 2012 | 08:00 PM
cubs4worldseris's Avatar
cubs4worldseris
Don't purchase G35 spec springs for your Z, it will not lower it as much. I have 350Z Tein S-Tech springs on my G and they provide a very nice drop. I cannot put my finger between the wheel and fender on the front, and can only fit one figure in-between the two on the rear.
Old Feb 2, 2012 | 08:25 AM
Gsedan35's Avatar
Gsedan35
Eibach 350Z Pro-Kit progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Old Feb 2, 2012 | 08:32 AM
Gsedan35's Avatar
Gsedan35
Will they work and install yes.
To they make any sense NO!
Rear spring rate is too soft and drop specs when mounted on your car are different
Your 2003 350Z has the following oem spring rates
314/342
Tein H-tech G35 coupe
ride height vs oem if installed on a 350Z -.1“/+.2“
Spring rates in lbs 324/260
Tein S-tech G35 coupe
ride height if installed on a 350Z -.7”/-.4”
Spring rates in LBS 358/274
Old Feb 2, 2012 | 05:14 PM
supraturboman
Ok sounds good. I will stick to the correct set up. Now have any of you used the Eibach Sportline springs?
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
