Alignment Specs afetr Lowering
Old Dec 30, 2003 | 05:01 PM
ms4awd's Avatar
ms4awd
Default Alignment Specs afetr Lowering
Hope everyone on the board had a merry christmas and a happy New year as well.
On to my question,
To the folks out there that have lowered their Zs. How much of a drop did u guys do and how did it affect the alignment specs. Were you guys still able to align back to spec. I was considering the Nismo S-tunes or the TEIN Basic kit. I believe the S-tunes still allow proper alingment with the 20mm drop. The TEINS i believe drop the car 1 inch up front and .8 inches in the rear. I would probabaly go with an inch at all four. that is if i can still get the alignment within spec. This is one of the things that will affect my decision with which to get. Any info is appreciated. Thanks
Old Dec 30, 2003 | 07:05 PM
kzshin's Avatar
kzshin
The S-tunes will be withing the spec, so you don't have to worry about it, plus it will still keep your car under warranty. Tein Basic is ride height adjustalbe, so as long as you don;t go to low, then it's okay. If Tein Basic kit can be worked with Tein upper Pillow mount like Tein Flex does (you have to ask Tein about this) you probably able to get it within the spec.
Old Dec 31, 2003 | 08:07 AM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
I have Tein S-Techs, drops only .7 and .6", so alignment specs were fine.
Bat™
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
