what will fix this toe?
Old Mar 26, 2012 | 07:15 AM
JDub03's Avatar
JDub03
Default what will fix this toe?
Toe arms or toe bolt
I've read an arm won't do anything and the bolt doesn't seem to be enough?
What will help?
Old Mar 26, 2012 | 07:30 AM
NZMOWND's Avatar
NZMOWND
depends on your suspension setup...if you have stock suspension then got toe bolts, if you have true coils then you can get a toe arm
Old Mar 26, 2012 | 07:58 AM
JDub03's Avatar
JDub03
Yea I have OEM style coilovers
Old Mar 26, 2012 | 08:08 AM
NZMOWND's Avatar
NZMOWND
than buy toebolts
Old Mar 26, 2012 | 08:40 AM
terrasmak's Avatar
Raising your car will help , then install some real tires.
Old Mar 26, 2012 | 08:46 AM
JDub03's Avatar
JDub03
Didn't see that coming
Old Mar 26, 2012 | 11:47 AM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
http://www.z1motorsports.com/350_g35...oducts_id=5091
SPL Rear Mid Links will give you plenty of adjustment and still let you use OEM style coilovers. You will want to grab some lockout washers as well. Pricey option, but the best way to do it imho (well, aside form getting true coils and toe arms!)
Old Mar 26, 2012 | 07:52 PM
Hella-flush now you want to fix it? I don't believe you.
Old Mar 26, 2012 | 09:55 PM
DjTyfightr's Avatar
DjTyfightr
go lower
Old Mar 27, 2012 | 05:40 AM
JDub03's Avatar
JDub03
LoL
do you see how bad that toe angle is. As soon as I can get the bolt in and fix this I'll be happy
Old Mar 27, 2012 | 05:41 AM
JDub03's Avatar
JDub03
Originally Posted by DjTyfightr
go lower
I had to go up to get the fender off the tire
Old Mar 27, 2012 | 05:57 AM
DjTyfightr's Avatar
DjTyfightr
Originally Posted by JDub03
LoL
Are you sure you aren't talking about camber and not toe?
Old Mar 27, 2012 | 06:04 AM
JDub03's Avatar
JDub03
I'm pretty sure I should of taken an above shot
Old Mar 27, 2012 | 07:55 AM
nismo4life11's Avatar
nismo4life11
Dont listen to this jamoke if your not on Koni Yellows and some sort of drop spring with 1" or less of drop with huge fat tires he sh**ts in your cornflakes. BTW terrasmak im pretty sure he didnt ask for you opinion on his setup.
You should be fine with the toe bolts, nice fitment btw what wheels you running? I find it interesting that it looks like you have toe out? I know with my work equips my coils and dialing out some camber for some more poke I ended up getting more toe in....
Old Mar 27, 2012 | 08:08 AM
JDub03's Avatar
JDub03
Thanks I knew someone like that would come along, doesn't bother me.
The toe out idk it might have just been off to begin with.
I got the varrstoen 222 19x10.5 0offset
Thanks again
Old Mar 27, 2012 | 09:33 AM
TURBOROADSTER's Avatar
TURBOROADSTER
Looks to me like he has excessive negative Camber and the Toe is out .
Old Mar 27, 2012 | 10:07 AM
Deedilus's Avatar
Deedilus
Toe bolts and an alignment. I'm not all into hellaflush-slam-the-****-outta-it-till-I-can't-drive it thing but the anti-stretch and anti-slam comments were absolutely hilarious.
Old Mar 27, 2012 | 10:45 AM
JaE35z's Avatar
JaE35z
Have you even tried to get an alignment? You might not even need aftermarket toe bolts
Old Mar 27, 2012 | 11:32 AM
JDub03's Avatar
JDub03
I was gonna attempt that afterwards but I already have the bolts just haven't got around to putting them in
Old Mar 27, 2012 | 11:49 AM
Deedilus's Avatar
Deedilus
