Alignment?
Old Apr 18, 2012 | 04:35 PM
transZendent's Avatar
transZendent
Default Alignment?
Hi guys! I did lowered my Z 7 months ago with a Tanabe Gf210 lowering springs
then i had them align with one of this Performance shop guys here in Orlando. I told them just to do the factory specs. After 7 months of driving i decided to take my Front wheels out myself for inspections. Here's what i found out! You guys have any idea what happen here? Any suggestions? Thank You!
Old Apr 18, 2012 | 04:56 PM
DavesZ#3's Avatar
DavesZ#3
Oh, I'll take a wild guess and say they didn't make it to "factory specs".
Old Apr 18, 2012 | 04:59 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Rub line looks thin to be camber wear. Rubbing on suspension components?
Old Apr 18, 2012 | 05:04 PM
Z1NONLY's Avatar
Z1NONLY
Both tires look like that, or just this one?
Old Apr 18, 2012 | 05:09 PM
taywan's Avatar
taywan
Wow. Sure is off or something isnt rt for sure. 7 months-u could've easily knocked back out of align if they had it right.
Old Apr 18, 2012 | 05:20 PM
transZendent
Yes both front tires are like that, i did checked if it is rubbing on something but i don't see any reasons. it's the inside corners of both tires are really rub off badly. Never had a chance to check it in 7 month because the car runs great! No vibrations felt of what so ever.
Old Apr 18, 2012 | 05:24 PM
Z1NONLY's Avatar
Z1NONLY
Waaay too much toe-out maybe?
Old Apr 18, 2012 | 05:30 PM
transZendent
The strange part of this is when you look at the front view of the two corners of the front tires are not even touching the ground. I don't know, What do you think experts?
Old Apr 18, 2012 | 05:45 PM
Z1NONLY's Avatar
Z1NONLY
I would turn the wheel all the way in each direction and ensure its not rubbing on the inner fender or something.
Also check the bushings on your suspension components for the front.
If you can't find any obvious reason for your tires to wear that way, take it in get the alignment checked.
Old Apr 18, 2012 | 05:52 PM
-Trav-'s Avatar
-Trav-
Did you get an alignment before or after you put those tires on? Getting an alignment with worn tires will only result in a misaligned suspension once you get new tires.
Also you should put up the alignment printout to confirm "factory specs"
Old Apr 18, 2012 | 05:53 PM
transZendent
Z1NONLY thanks! i will do that! my 2006 350z had 37,000 miles.
Old Apr 18, 2012 | 05:59 PM
transZendent
I had those tires since 5 years ago with stock springs and still i had a good tread in it. Only happened when i put those lowering spring and they didn't gave me a print out for the alignment.
Old Apr 18, 2012 | 10:40 PM
terrasmak's Avatar
Do you have adjustable front arms? If not you are not in OEM specs. Also, yoru compression arm bushings are probably shot, it probably aligned out close to OEM spec, the bushings fail from being lowered and your alignment is now off. Last, that looks like toe wear, without the bushings fail, the Z slightly gains toe and needs be be aligned often.
Old Apr 18, 2012 | 11:59 PM
Thats not too bad. Keep your speed under 100 MPH and you should be OK.
Old Apr 19, 2012 | 02:49 PM
User 42426's Avatar
User 42426
if you are worried about safety, that should be ok to drive on. I once had all four tires bald to the point where wires were showing all over.
Old Apr 19, 2012 | 03:43 PM
Z1NONLY's Avatar
Z1NONLY
I wouldn't drive on that tire unless I absolutely had to.
Old Apr 19, 2012 | 03:54 PM
transZendent
Nope!!! I don't think so!! Safety first! Can't drive that kind of tires conditions here in Orlando! Hot pavements! You are just asking for an accidents!
emooheo
Oct 14, 2015 08:58 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
