Looking for info on 350z/370z knuckles/hubs
Old May 1, 2012 | 10:33 AM
A.Dutsov's Avatar
A.Dutsov
Default Looking for info on 350z/370z knuckles/hubs
Hi, i am new to the forum, so first of all Hi from Bulgaria. I need some dimensions if you have, the 350z and 370z front and rear hubs look similar, but are they same bolt pattern/size? and same center hole, i mean the knuckle side, not the wheel side ... i also need the offset(the size in mm from the place the hub meet the knuckle to the place the hub meet the wheel). I want to make front knuckles for my drift car, its 200sx, and i want to use z370 front hubs, so i need as much as possible info ... maybe some knuckle drowing, or sizes between bolts, and center hole(the big one of the center of the front/rear knuckle ...) because my rear hub seem to be like z32/z33 rear hubs, and if so, i can use my rear one to design my front knuckle to be bolt on type instead of using spindle. Not sure if you understand me right, or if i say it right ... so if you dont uderstand what dimensions i need, i can make some drawing ...
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
