Uneven Suspension Height
Old Jul 6, 2012 | 11:31 PM
JDMStanced's Avatar
JDMStanced
Default Uneven Suspension Height
i noticed that my front left side sticks out more than the right side does.
Am i the only one having this issue? Due to this, one side looks more sunk than other side. My car is quite low and it's at -25 offset front.
Old Jul 7, 2012 | 03:50 AM
JCITY's Avatar
JCITY
New to me...
The obvious question would be,what kind of wheels do you have?
Is it possible that the side that you are saying sticks out more has
a wheel with a different offset?Maybe one wheel by mistake has
a different offset?Or,just a error when they were made?
How low is quite low?There may be a problem in this area that would cause
what you are experiencing.Did the wheel stick out BEFORE you lowered?
Old Jul 7, 2012 | 08:01 AM
415mm's Avatar
415mm
Professional
How big of a diff is it? It could just be the one side is higher and has less camber making it look like it sticks out more. Try lowering just the side that sticks out a little more, it should sink/camber in or if you have adjustable front arms adjust it that way. It could help.
Old Jul 7, 2012 | 06:35 PM
Waiz's Avatar
Waiz
I would suggest getting corner balanced, you probably aren't level on all four corners
350Z_Al
Oct 29, 2020 07:44 PM
