Rear Camber Kits
Old Aug 21, 2012 | 06:55 PM
35028's Avatar
35028
Default Rear Camber Kits
I am currently running Ichiba rear camber arms. Although not the best, they say that they are suppose to have +/- negative 4 camber adjustment. With that said I have managed to max out the arms and can't gain anymore positive camber. I feel like I should be able too.
I am going to try a different camber kit but I am not sure what to buy. SPC has a kit but it claims the same +/- as ichiba...
I would like to gain at least another 1 to 2 degrees of positive camber as I am sitting at around -3 or -4
Are there any kits out there built to help slammed cars or am I just out of luck? I have had no luck researching on google for kits.
Old Aug 21, 2012 | 07:32 PM
terrasmak's Avatar
Use your arms in conjunction with you camber bolts.
Old Aug 21, 2012 | 07:43 PM
35028's Avatar
35028
Stock bolts don't provide enough adjustment. I am thinking about getting the SPC kit, assuming that the bolts that come with that will provide even more camber adjustment? Or I may be wrong. I guess you get what you pay for, as the ichibas only ran me about 70 bucks a couple years ago if I can remember.
Old Aug 23, 2012 | 09:46 AM
travlee's Avatar
travlee
Master
hit up jason z-ya on here.... he is an engineer and builds alot of his own parts... he might be able to help you or lead you in right direction
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
