Tein flex coilover knocking / clunking
Old Nov 12, 2012 | 11:51 PM
tiki's Avatar
tiki
Default Tein flex coilover knocking / clunking
Part: Tein Flex Front Drivers side.
Issue: Clunking / Knocking completely loose sounds and causes the car to shake from improper "connections" somewhere in the top of the shock housing.
The clunking is coming from inside the assembly above the ring pictured.
The ring is loose.
Any ideas? Pillowball?
Thanks for your help!
Old Nov 13, 2012 | 03:40 AM
Bober'z's Avatar
Bober'z
the pillow ball mount is usually loose, they don't tighten them all the way from the factory, so i would start there
Old Nov 13, 2012 | 05:52 AM
nachospizza's Avatar
nachospizza
It is probably the Ball Join Bearing wore out need to replace a new one!!!
Old Nov 13, 2012 | 08:55 AM
pro_350z's Avatar
pro_350z
+1 I see it all the time
Old Nov 13, 2012 | 02:41 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
+1
A lot of times parts like this aren't tightened to what they should be.
Old Nov 14, 2012 | 07:19 AM
tiki's Avatar
tiki
How do I tighten it? I was practicing drifting and rolled up onto the curb so I wouldn't doubt if it was more than loose, noisy since.
Old Nov 14, 2012 | 08:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I hate it when curbs get in the way of drifting.
Old Nov 17, 2012 | 12:58 PM
tiki's Avatar
tiki
Any idea how to tighten?
Old Nov 18, 2012 | 06:20 PM
suprasam's Avatar
suprasam
Tighten the nut at the top. I recommend taking them off.
Old Nov 21, 2012 | 05:40 PM
tiki's Avatar
tiki
thanks
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
