Rear Poly Spring Mount mod
Old Feb 18, 2016 | 06:48 PM
  #61
mlillyballin's Avatar
mlillyballin
just wanted to clear things up before I go to install these on my car. Is this the correct way to do it? just doesn't seem too secure.
Old Feb 19, 2016 | 02:57 AM
  #62
travlee's Avatar
travlee
Master
once you get it there, with the pressure of the spring and weight of the car, it is not going anywhere
Old Feb 19, 2016 | 08:53 PM
  #63
mlillyballin
thanks for the info. got them on this morning with no problems. still working on getting the top hats off my front struts to install the springs
Old Jan 6, 2017 | 07:22 AM
  #64
TheeVirtuoso's Avatar
TheeVirtuoso
Just ordered these, thanks everyone this looks like the perfect solution to what I was looking for.
Old Apr 8, 2017 | 11:01 PM
  #65
AnthonyJ350's Avatar
AnthonyJ350
Just finished putting these in my car and I'm really happy with the subtle drop and the ride quality is virtually the same (just a little bit more firm).
Old Apr 10, 2017 | 01:44 PM
  #66
JMII's Avatar
JMII
Thumbs up
AnthonyJ350 - great video... I have been checking out some of your others
Old Apr 13, 2017 | 06:46 AM
  #67
AnthonyJ350
Glad yo're liking them!
Old Apr 13, 2017 | 10:30 PM
  #68
MicVelo's Avatar
350Z/370Z Tech Moderator
Anthony, never knew you were on this forum until now. I too sub'd to your YT channel a while back because I thought there was quality stuff. Awesome you're on here!
Old Apr 13, 2017 | 10:55 PM
  #69
AnthonyJ350
Thanks for your viewership! Ya I like using the site for research because there's some good info on here (but you always have to verify). I don't post too often, only if I think a video has value for others.
Old Jun 28, 2017 | 01:13 PM
  #70
liv2apex's Avatar
liv2apex
Originally Posted by POS VETT
The pads will move around since the ID is is larger than the tabs that keep the original mounts in place.
This very true, and unless your car is a garage/trailer queen, I highly recommend you stay away from this!
Mine were on for less than one month, and the springs had moved more than 50% off the mounts!
Not something you want to happen while driving.
Old Jun 28, 2017 | 01:15 PM
  #71
liv2apex's Avatar
liv2apex
To clear things up, It's NOT secure!
Old May 10, 2018 | 09:41 AM
  #72
ARRRT's Avatar
ARRRT
I confirm that this is NOt safe!
I've mounted this items from energy suspension and after week my drivers' side spring literary slept off it...
Better keep away from this POS, guys!!!
Old May 10, 2018 | 08:50 PM
  #73
mr. sparco's Avatar
mr. sparco
Might be your lowering spring length causing it to slip out. I converted my Tokico DS2 rear springs to adjustable sleeves with even thinner isolators to separate the coilover from the body. Been like this for a few years now. No issues even with spirited canyon runs and hard corners.
Old May 17, 2018 | 10:54 AM
  #74
Desert Z's Avatar
Desert Z
Originally Posted by DRELOC
I just lowered my Z on Sportlines let it settled & the rear still rakes for some reason & i could literally almost put my whole fist in the wheel gap. That's why I bought 2 different size just in case i need it to lower more to get an even look.
Any updates?
This happened to me also with the same part # that everybody has ordering. Car has s techs on stock shocks and the rear looks stock.
Yes, i have installed suspension on tons of cars in the past and i was mindful of the preload on the bushings.
I will order the thinner part number than everyone has and report back.
Old Jul 6, 2018 | 02:19 PM
  #75
Desert Z's Avatar
Desert Z
Originally Posted by Desert Z
Any updates?
Ok so I went on the Energy suspension website and I found that 9.6101G (for a Toyota Rav4) has the same specs except it's even slimmer. I installed them and my car (06 Track) now sits at the proper height. RAKE IS GONE!!!
For those who care for NVH i wrapped the top few coils in heat shrink tubing. This got rid of a rubbing type noise the coils made when they compress. One less noise, check
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
