Bleeder newbee help.
Old Oct 19, 2013 | 08:58 AM
Zume's Avatar
Zume
Talking Bleeder newbee help.
This is my first time attemptting to bleed my brakes.
G35 cpe w/ AP Racing big brake kit. Bleeders appear to be ~ 8.5mm OD.
I will be using suction from this-
Bleeders-
My question is which bleeder do I use. I assume "A". Do I open up "B" bleeder at all? Think this is refered to as "outside/inside".
Old Oct 19, 2013 | 10:04 AM
BY350z's Avatar
BY350z
You bleed B side first then A (inside/outside) don't open both valves take your time and do one at a time. Also, this is my opinion but I wouldn't use that bleeder tool, their notorious for leaving air bubbles in your system. I recommend the motive power bleeder, best $70 I'd ever spend makes bleeding brakes so easy.
Old Oct 19, 2013 | 11:50 AM
terrasmak's Avatar
Once you get A done. , go back to B for another pump.
Old Oct 19, 2013 | 12:14 PM
Zume's Avatar
Zume
THX
Old Oct 20, 2013 | 04:11 PM
thekinn's Avatar
thekinn
That picture is the right idea, but technically, the clutch is being bled in the picture not the brakes. And I think that is a Wilwood reservoir swap - not OEM clutch reservoir..
So yeah, get a Motiv bleeder and hook it up to the brake reservoir.
Old Oct 20, 2013 | 05:34 PM
taywan's Avatar
taywan
I'm going to put that on my Xmas list.
Chris350z03
Oct 8, 2023 07:19 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
_koubie_
Sep 20, 2015 06:34 PM
