rear upper a arm
Old Dec 25, 2013 | 09:44 AM
joshua350z6841's Avatar
joshua350z6841
Default rear upper a arm
looking for a after market rear upper a arm. got spl everything else. spl dosnt make a replacement for this. this is all i could find as a replacement.
looking for best track setup.
http://www.nengun.com/ikeya-formula/rear-upper-arms
Attached Thumbnails rear upper a arm-nengun-0644-00-ikeyaformula-rear_upper_arms.png   rear upper a arm-18339_02.jpg   rear upper a arm-wl350zbush.jpg
Last edited by joshua350z6841; Dec 25, 2013 at 05:47 PM. Reason: better description
Old Dec 25, 2013 | 02:50 PM
guitman32's Avatar
guitman32
Is that balljoint serviceable (can it be pressed out and replaced)?
I see off the bat there is no zerk fitting for grease, its a pretty easy location on the BJ (no significant rotation), but still if its a cheap piece or the seal around the boot is bad ive seen balljoints go very quickly (<5k mi).
What are your bushing options for that piece should you decide to replace (are they OEM diameter)?
Lastly just curious whats wrong with your arm?
Old Dec 25, 2013 | 05:44 PM
joshua350z6841
nothing is wrong. just trying to make it as solid as possible. thought about pressing the two bushings out an seeing what i could put in their to make it solid. an the ball joint would be hard to get to. would probable have to remove hub.
just trying to make ready for the track.
Old Dec 26, 2013 | 02:23 AM
terrasmak's Avatar
I have not got around to it, right now I have Whiteline bushings in the upper a arm location and would like to get a set of custom Delrin bushings made.
Old Dec 26, 2013 | 03:48 AM
travlee's Avatar
travlee
Master
if it was me, i could find better things to spend that $800 on, my theory is if it aint broke, dont fix it. that is the only reason i havent replaced my clutch yet
Old Dec 26, 2013 | 04:15 AM
joshua350z6841
thanks terrasmak. i will look into delrin. was thinking about getting the specs an calling spl an seeing if they have anything that would work or could make.
Old Dec 26, 2013 | 04:18 AM
joshua350z6841
Originally Posted by travlee9374
if it was me, i could find better things to spend that $800 on, my theory is if it aint broke, don't fix it. that is the only reason i haven't replaced my clutch yet
if it fails at the level i will want to push it their will be more the 800 in damage. also i dont think it will fail but i want to remove any slop or play.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
