Negative Camber? HELP!
Old Jan 5, 2014 | 09:04 PM
Maffucci10's Avatar
Maffucci10
Default Negative Camber? HELP!
Ok so a friend was following tonight and noticed my rear tires were pointing in at the top. Ive never noticed this before and I feel like is just started to happen. The past like week ive been taking my car out a couple of times to drift around in the snow/wet... could that have caused this to happen? Or do I just need to get a rear alignment? Thanks. And sry for the shitty pictures lol
Old Jan 5, 2014 | 09:36 PM
Emski's Avatar
Emski
You are suppose to have negative camber. If you are worried go get it checked out.
Old Jan 5, 2014 | 09:39 PM
Maffucci10's Avatar
Maffucci10
I know youre supposed to have some degree of negative camber, but I feel like this is too much.
Old Jan 5, 2014 | 10:34 PM
terrasmak's Avatar
Only way to find out is put it on a rack or look upeasuring it yourself on a lever surface
Old Jan 6, 2014 | 05:09 AM
350slug's Avatar
350slug
If u were sliding around there could be a chance that your eccentric bolts slipped and your out of spec
Old Jan 7, 2014 | 05:35 PM
AARONHL's Avatar
AARONHL
Ya your Toe could be off an it's giving the appearance of a different camber. If you car is stock, rear camber can only be adjusted a little I believe...so bring it to an alignment shop
Old Jan 9, 2014 | 07:13 AM
driftsucky's Avatar
driftsucky
drift in the other direction. Problem fixes itself. What else ya got.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
