PBM Camber Arms and Circuit Sports Eccentric Lockout Review
First off PBM is top tier for adjustable links. The quality is amazing and the adjustability is better than any company out there.
Price: $250
Features:
~ lifetime manufacturers defect warranty
~ All steel tubular construction
~ Teflon lined spherical bearings
~ Forged Clamping rod end receiver
~ Forged Clamping double threaded adjuster makes double sure your settings never come loose
~ Super long adjuster threads have the most thread overlap and more adjustability than anything on the market
~ Adjuster away from the subframe, on the knuckle side for easier adjustments
~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion
~ Laser cut reinforced mounting bracket
~ Copper and Gold plated finish
This is a comparison with my Megans that were almost maxed out. As you can tell the PBM offer a great deal of adjustability. The double lockers make sure the alignment settings will not move. Adjusting them is very easy with the use of a large adjustable wrench. No need to remove the lock bolts.
The Circuit Sports lockout washers are great for the money. I paid $22 shipped on ebay. They remove the eccentric washers and make sure the alignment is spot on. They come with very high grade treated hardware. The washers are lazer cut for precision and the can be installed/uninstalled without removing the swaybar.
Price:~$22 on ebay
My pup taking the car out for a test drive.
Price: $250
Features:
Price:~$22 on ebay
congrats , glad you love them , they look great
I am torn between these and the SPL
I just put SPL front upper control arms on the car, and the SPL front tie rod ends
I want to replace my rear ichiba camber arms and I was going to use the SPL
money is about the same on the camber arms from SPL to PBM
what makes you feel they are better then the SPL
all things considered
spl vs pbm
on camber arms
are the pretty much very close as far as quality and performance
or is one much better than the other
for me I do not track , or drift
simply street driven
spl vs pbm
on camber arms
Craftsmanship - on par
Bearings - on par
warranty - on par
my personal choice was PBM because of the adjustment on the knuckle side and the double lockers. They also look pretty
That is quite the title. Stance does use Aurora bearings but I guarantee they are not using MilSpec rod ends. The bearings on Stance, PBM, and SPL will all be fine for street or track.
The PBMs look sick and are the same quality from what I've seen as the SPL I am buying camber arms tomorrow and would like the PBM ones but they are ALWAYS out of stock so I may be stuck with SPL not that that's bad though.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
