Megan Racing Ball Joint - only two years lifespan?
Old Jan 21, 2015 | 01:33 PM
Tifferzzz's Avatar
Tifferzzz
Default Megan Racing Ball Joint - only two years lifespan?
In 2012 I had to replace my lower ball joint on my front right. This is when the other Z site was up (prior to being hacked). I did a lot of research, went through recommendations, and tried to determine if an OEM or aftermarket would be better. The problem with the OEM is that it also includes everything - the entire arm, bearing, and ball joint - and is thustly a $400+ part. So I was able to find (through Megan Racing) the ball joint that was just that - the broken part that needed to be replaced.
Fast forward two years later when I took my car over to have the safety done, and low and behold I need a new ball joint. I don't race my car. I don't live in a city with high and rough terrain, or even snow. I drive about 6k miles a year.
I've decided to replace this replacement with the full OEM arm. My question is - is it common to blow through a ball joint that fast - especially in an aftermarket part like that?
Old Jan 21, 2015 | 06:36 PM
terrasmak's Avatar
Do they check the joint or boot? Most people are not actually wearing out the joint, just have a cracked boot. Then replace them with a low quality joint and boot combo.
Old Jan 22, 2015 | 06:30 AM
guitman32's Avatar
guitman32
Believe it or not, two years is an impressive lifespan for a cheap aftermarket balljoint, assuming yours is actually bad and doesn't just have a torn boot.
Old Jan 22, 2015 | 11:06 AM
Tifferzzz's Avatar
Tifferzzz
The boot is torn but they're saying that it's bad because of the over-movement of my tire. There's enough play in it that it won't pass safety.
Old Jan 23, 2015 | 01:56 PM
guitman32's Avatar
guitman32
You need to verify with your own eyes that there is play in the joint. Your tire can have many reasons for play.
Old Apr 30, 2015 | 10:05 AM
Cheeko's Avatar
Cheeko
I'm looking to replace the ball joints on my compression rods. Can someone suggest a good aftermarket ball joint?
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
