Stance coilover - initial damping suggestion
Old Apr 20, 2015 | 12:29 PM
ZROCM's Avatar
ZROCM
Default Stance coilover - initial damping suggestion
I installed a set of Stance coilovers. Just lowered my '04 350Z an inch from stock height. I haven't finalized the height yet, but I believe one shouldn't go lower than 1.25 inches, otherwise the handling is not as good as OEM. I have the following tire sizes: 245-40x18 +25 offset on the front and 275-40X18 +22 offset in the rear. I realize that damping settings are a personal preference, but wondering what people have found to be close to OEM or somewhat firmer. Also wondering if people have set damping different on the front vs. the rear.
My objective is not to be running specifically on the track, but spirited driving the curvy country roads and everyday usage.
Thanks in advance for any advice.
Old Apr 22, 2015 | 09:10 AM
driftsucky's Avatar
driftsucky
For that height, there isn't going to be a "great" dampening solution because they aren't meant to stay that high. You should've gone with a KW or Tien solution if you didn't really want to lower your car more than that. Just my $.02
As for dampening, most people dampen based on height/driving style. My rears are stiffer than my fronts because I slide my car at things. If you don't, you may want a softer ride. Some people have super stiff settings because their wheels/tires may be millimeters from their fenders and they need minimal bounce. At the height you're at, I'd imagine whatever they're set at from factory would suffice.
Old Apr 22, 2015 | 09:18 AM
terrasmak's Avatar
Well it all depends on how they are set up, if you did the normal couple MM of preload and set height with damper length it will be the same ( possibly ) crummy setup as someone who is slammed.
Damper settings, start soft, softest setting are the fastest on the track. Actually setting the dampers for performance is a guess unless your tuning at the limit on the track. If your not tuning on a track, just set to what you think feels good at the speed you push the car to.
Old Apr 22, 2015 | 09:23 AM
ZROCM's Avatar
ZROCM
OK, thanks. I have no preload set and the car is sitting 1 inch lower than stock. Should I raise the car some? I also assume an expert needs to adjust the pre-load. My Stance Coilovers have Swift springs: 13K in the front and 9K in the rear.
Thanks much for you help.
Old Apr 22, 2015 | 09:28 AM
terrasmak's Avatar
The preload thing is a myth and load of .... Set your suspension travel with shock body length , then set ride height with spring load.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
