Which other cars have the same size springs?
Old Jul 20, 2015 | 10:40 PM
openupitsdave's Avatar
openupitsdave
Default Which other cars have the same size springs?
Im sure the G35 does.. any other cars use the same springs?
Im asking because im looking for a set of used Eibach Pros on Craigslist.. No results for a 350z in my area :[ Suprised actually..
Old Jul 21, 2015 | 08:51 PM
openupitsdave
I should have mentioned that its for a 2003 touring 6-speed.. Sorry
Old Jul 21, 2015 | 11:55 PM
terrasmak's Avatar
Just order a set online
Old Jul 22, 2015 | 12:33 AM
openupitsdave
Old Jul 22, 2015 | 09:21 PM
terrasmak's Avatar
G35 spring can work, not the best but they will fit
Old Jul 22, 2015 | 11:39 PM
DesertSleeper's Avatar
DesertSleeper
Even if there were, u don't wanna use a spring that isn't designed for the z. The only known compatible, as previously stated, would be the G35 springs, but being designed to hold more weight, u would end up with half the drop advertised, if that. New pro kits go for around $250ish shipped, save up and do it right.
Old Jul 22, 2015 | 11:49 PM
nizmo_0385's Avatar
nizmo_0385
Agreed. Just because it fits doesn't mean that its right. The spring rates arent for the Z. OP. Cruise the FS section or ebay you may find some there
Old Jul 23, 2015 | 03:07 PM
openupitsdave
Thanks guys.. any springs with same spring rates/size?
Also, I see a lot of varied suggestions on what brand springs to buy. I always thought Eibach was the way to go, but Im seeing a lot of people saying to go with Tein or Tanabe.... thoughts?
Old Jul 23, 2015 | 03:31 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Opening myself up for righteous criticism here but frankly, almost any of the top name springs will do just fine for street use. What's MORE important in this equation is what you use to control the spring motion.... SHOCKS.
Read this thread:
https://my350z.com/forum/brakes-and-...coil-over.html
Boy, I ref that one a lot... and not cuz I contributed to it but because almost all of the springs at the top of the heap - Eibach, Hotchkis, Tein, Nismo, etc. - are mentioned and are used by all of the contributors.
I'm partial to Eibach, others swear by the Tein units, etc. Common thread tying a lot of that discussion together are the top branded shocks used with them, Bilstein, Koni, Tokico and so forth.
Over my many years of messing with suspension set ups, I have found that springs are the one component that get talked about the most but in reality, are NOT the piece to get AS over-analytical about versus shocks, sway bars, alignment, tires. Springs hold up your car and there's not nearly the science in them as with the other components. Stick with the top brands and in six months you won't even think about 'em again.
Flame suit on....
Mic
Old Jul 23, 2015 | 03:37 PM
DesertSleeper
Difficult question to answer without knowing what goals you have for your car.....are you going for performance or looks? How low are u looking to go? Is it a daily driver or track vehicle? These are all things u need to take into consideration when choosing a spring.
Eibach has a great reputation, but a lot of the track guys have reported them being unpredictable when pushed to the limit due to their progressive design. For track it's better to go with linear springs.
So everyone's opinion will be different based on their needs......
Old Jul 23, 2015 | 03:54 PM
openupitsdave
I dont plan on tracking my car but I do like to have an 'in-control' feel when im spirited driving.. I really only want an inch drop. I heard anything past that will require camber arms and toes...
I dont want to pay too much on shocks...Actually anything that is suited for an inch drop and is around the same price, or a little more than OEM shocks, is good enough for me...Of course they must be decent sport ones though, but still comfortable enough as DD....
Maybe a good all-around shock?
Old Jul 23, 2015 | 04:11 PM
travlee's Avatar
travlee
Master
you shouldn't be cheap on suspension... but the cheapest will be bilstein shock and eibach pro kit springs
Old Jul 23, 2015 | 04:20 PM
terrasmak's Avatar
Swift would probably be my Go To spring. Springs make a difference as noted above, but unless you track the car and know exactly what you need, most aftermarket springs will be fine. Just pic the drop you want, if you have problems, it's most likely do to crappy shocks
Old Jul 23, 2015 | 04:21 PM
travlee's Avatar
travlee
Master
swift are nice, but i don't see him paying for them
Old Jul 23, 2015 | 05:00 PM
MicVelo's Avatar
"Best" shock in the realm of OEM are likely the Tokico Blues. ~$500/set. Pair that with a decent set of springs, be they Tein, Eibach, whatever fits your budget should work. (Others people talk about: KYB GR2, supposedly close to stock. Me, I won't touch 'em after premature failure of a set of this brand many years ago.) You DO get what you pay for.
However, keep in mind the order of things (for handling IMPROVEMENT):
Good Tires
Good Alignment
Anti-sway bars
Shocks
Springs
Alignment adjustability (if needed)
In that order as budget allows.
Too many people start with springs....for the look. And that's OK if that's what one is going for. Looks. Doing it right is a whole 'nother matter.
Old Jul 23, 2015 | 05:39 PM
DesertSleeper
I have Hotchkis springs and Tokico Blue shocks. They work well together. The blues should pair up well with pro kits too. They're no bilsteins but they're a decent 60k mile shock for the price
Old Jul 23, 2015 | 05:44 PM
travlee's Avatar
travlee
Master
i had the d-specs and loved em... but don't think they are available anymore
Old Jul 23, 2015 | 05:49 PM
mr. sparco's Avatar
mr. sparco
Originally Posted by Gsedan35
Just posting this to provide information for more informed choices.
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2008 (revised suspension)
Front:314 Rear:427
Nismo Z (2007-2008) ride height is the same as other Z models linear front, progressive rear (initial and final rates shown)
492/336-672
Eibach 350Z progressive springs 1”/1” drop* on 350Z G35 drops will be higher
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach G35 Coupe progressive springs 1.1”/1” drop on G35 coupe
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Eibach G35 Sedan 1.1”/1.1” drop on sedan
Spring rates in LBS initial/final front 259/334 initial/final rear 359/416
Side Note: The sedan Eibachs were developed on a non sport sedan, they did not use a sport suspended car to do the R&D work.
Eibach 350Z sportline progressive springs 1.2"/1.2" drop G35 drops will be higher
F: 239/400 R: 257/435
Eibach G35 Sedan sportline progressive springs 1.6"/1.6" drop
F: 171/400 R: 285-502
RSR 350Z linear springs .6”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 345/417
RSR G35 coupe progressive springs 1”/1” G35 coupe drop
Spring rates in LBS 315/315
Beware, a 1" drop spring with NO increase in stiffness vs oem.
Hotchkis 350Z Linear springs .6”/.8” drop on 350Z G35 drops will be higher
Spring rates in lbs 340/330
Cobb Tuning 350Z Linear springs .75"/.9" drop G35 drops will be higher
Spring rates 436/535 (as shown here http://g35driver.com/forums/brakes-s...new-parts.html )
UPDATE 7/18/11: Cobb discontinued this spring some time ago, some resellers might still have a set or you might have to make a wanted to buy thread to find a set.
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tein H-tech G35 (fronts are progressive, rears are linear) coupe drop .6"/.3" sedan drop 1.4"/.7"
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Tein S-tech G35(fronts are progressive, rears are linear) coupe drop 1.2"/.9" sedan drop 2"/1.3"
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
G35 - DSK509 - 240f/300r - Linear Springs
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5" (2"/2.5" drop if installed on a G35 sedan. 1.5"/2" if installed on a G35 coupe)
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 314/353
Beware, a 1.2" drop spring is no increase in stiffness vs oem, G35 users have it even worse since your oem shocks are 3/4" taller vs oem Z shocks.
Tanabe NF210 Springs G35 COUPE progressive springs 1”/,6” drop on G35 coupe G35 sedan drop will be higher
Spring rates in LBS 297/336
Beware, a 1" drop on springs that are softer then oem springs.
Tanabe DF210 G35 COUPE progressive springs 1.7”/1.3” drop on G35 coupe, G35 sedan drop will be higher
Spring rates in LBS 308 /353
Beware, a 1.7" drop in the front on a spring that is softer then oem
Tanabe NF210 G35 SEDAN progressive springs 1.6”/.9” drop on G35 sedan
Spring rates in LBS 297/269
Beware, a large drop on springs that are softer then oem.
Tanabe DF210 G35 SEDAN progressive springs 1.7”/1.5” drop on G35 sedan
Spring rates in LBS 286/280
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2"/1"
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Swift G35 coupe linear springs 1”/.6” drop on G coupe, G35 sedan drop will be higher)
Spring rates in LBS 280/314 (softer then oem)
Beware, spring rates are softer then oem.
Nismo T2 350Z Linear springs 1”/1” drop on 350Z
DO NOT RUN THESE WITH OEM SHOCKS OF ANY KIND! TCKline DA's were specifically designed for these springs, however I'd pony up for AST4100's or Anze Engineering Penskes
Listed for information ONLY!
Spring rates in LBS 690/690
Vogtland 350z progressive springs 1”/1” drop on 350Z G35 drop will be higher
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm springs 350Z
DRacing 30mm drop
Spring rates in LBS initial/final front 252/454 initial/final 252/482 rear
Espelir G35 coupe progressive springs .4"/.4" drop
Spring rates 409/515 (rear rate IMO is too high for all oem shocks, Z or G)
Espelir 350Z progressive springs .4"/.4" drop (G35 drops higher)
Spring rates 386/515 (rear rate IMO is too high for all oem shocks, Z or G)
H&R sport springs G35 coupe (progressive springs)
1.1"/1" drop
no spring rate info H&R refuses to give it out, something that is critical to making a informed buying decision, buyer beware)
H&R sport springs G35 sedan (progressive springs)
1.3"/1.2"
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Skunk2 G35 coupe
Same specs as 350Z, which is strange because normally G35 spec springs have different spring rates and generally a slightly different drop
Old post from Gsedan35 but good info to have on hand. Spring rates for Gs.
Old Jul 23, 2015 | 07:32 PM
DesertSleeper
There you go OP, the lowering spring bible, all the info u need to make a wise decision......
Old Jan 6, 2016 | 04:18 AM
openupitsdave
Bringing this post back since im now in the market for shocks. I did some digging around for a few hours and came up with these prices. Amazon and Ebay. Free shipping to California.
Monroe OE - $253
KYB - $272
Tokico HP - $350
Tokico D-Spec $673
Nissan OEM - $710
Bilstein - $740
Koni - $951
Im trying to decide what shocks would pair best with Eibach ProKit springs. Im aiming for the $300 price range so im stuck between the Tokico HP's(blues) or the KYB ExcelG's (GR2)....
Tokico vs KYB whats it gonna be?
