Noises from wheel area after akebono install
Old Nov 30, 2015 | 09:25 PM
emooheo's Avatar
emooheo
Default Noises from wheel area after akebono install
Hi all,
I installed akebono brakes on my 350z this weekend and took it for a drive. Everything seems to work correctly but I am hearing noises. There is a clunking/squeaking sound coming from the front. There is also scraping sound coming from rear rotors (maybe e brake rubbing? or left over heat shield?). I made sure everything is nice and tight. Took off wheel and tried shaking rotors and felt solid.
Here is a video I took (terrible quality but the sound is there, this is when driving in circles with wheel turned).
Anyone have any clues what they think it is?
Old Dec 1, 2015 | 04:47 AM
turboed350z's Avatar
turboed350z
Did you use brake grease?
Old Dec 1, 2015 | 08:16 AM
JMII's Avatar
JMII
Did you bed in the pads? Are the calipers scraping the rims? On my Touring 18"s the clearance is like 2mm thus even a wheel weight would scrape. Are the dust/heat shields in the back touching or have any bend edges left over from trimming? Are the pins and shims installed correctly? Wheels/rims torqued down properly?
Sorry just throwing out random guesses My rears squeaked until I got one good track day with them, that seemed to really bed them in fully. However that was more of a pad/rotor mating type problem, which you might have too. I didn't use any grease because the back of pads already had a soft coating on them. Maybe the pads and shims could use some grease
Old Dec 1, 2015 | 08:28 AM
turboed350z
My cousin stock brakes would squeal like a pig backing out of driveways. A little grease solved the problem.
Old Dec 6, 2015 | 08:05 PM
calibredz33's Avatar
calibredz33
are your rotors shot? need them to be re-surfaced/ just new ones installed?properly bedding the brakes, then braking them in really helps with feel, and noise after some time.
ValvetVipe
Videos
Dec 1, 2015 09:49 AM
Joe clan
Nov 28, 2015 10:38 AM
05350z
Wheels Tires
Nov 28, 2015 06:30 AM
