ABS or braking fault
Old Feb 2, 2016 | 09:48 AM
Matt Watson's Avatar
Matt Watson
Default ABS or braking fault
Hi guys, I've read posts from people who have similar fails but never seen the solution ...
So, I have an 03 350z coupe and the brakes lock on after 5minutes of driving. ABS and 2 other fault lights illuminate. If I disconnect one plug on the abs pump, reconnect, start the car and accelerate, I feel a clunk around the brake pedal area and the brakes release only to play up again.
I have changed the ABS pump already, it didn't make a difference. I have a feeling that something is failing at operating temperature as the fault comes evry time after 5mins. Any suggestions ?
Thanks guys
Old Feb 2, 2016 | 10:03 AM
eZg's Avatar
eZg
Have you checked to see if it's throwing any codes?
Sounds like may be ABS/speed sensor.
Old Feb 2, 2016 | 11:40 AM
Matt Watson
I haven't been able to scan it as I can't drive it to a dealer. I don't overly want to get it towed there. I thought maybe a speed sensor, but it's something that occurs at operating temperature that is causing the fault I believe. I'm wondering whether it could be vacuum related, like some form of solenoid that opens at operating temperature..
Old Feb 2, 2016 | 11:47 AM
eZg's Avatar
eZg
Try going in the Brake and Suspension Tech area and searching threads.
Good luck!
tclark90
Nov 7, 2016 06:55 PM
KJFire4Life
May 24, 2016 10:17 AM
Reece350z
Feb 2, 2016 10:30 AM
EnjukuRacing
Drivetrain
Feb 1, 2016 01:26 PM
manny1274
Jan 27, 2016 02:27 PM
