Toe bolts spinning when adjusting
Old Jun 20, 2016 | 04:34 PM
350zaddict's Avatar
350zaddict
Default Toe bolts spinning when adjusting
Hey guys I had a question I recently got my z aligned and we put the rear camber arms and spc rear toe bolts. we put the bolts on with no issue my auto teacher said we didn't have to do any drilling so I trusted him. Before these bolts my toe was 1.5 degrees on the left side. As soon as I put the bolts on it was to zero instantly lol. But the next day I adjusted the rear again because the camber was off due to the fact we forgot to tighten down the nut for it. And the toe was like .07 and I was like let me adjust it to zero again and as soon I adjusted it the nut spun and goes crazy up!! Closest I can get to it is .21 and it's making me mad? What did I do wrong. The 2 rounded spots in the middle of the bolt where the bolt goes is kinda stripping on the left side. Will drilling to the template specs fix this?
Old Jun 20, 2016 | 10:01 PM
terrasmak's Avatar
Sounds like you tightened them to much and screwed the threads
Old Jun 21, 2016 | 03:08 AM
350zaddict's Avatar
350zaddict
It's not the nut that spins though? It's the actual washer that spins
Old Jun 21, 2016 | 09:28 PM
terrasmak's Avatar
So the bolt slides in the washer, it's because you forced the bolt without enlarging the hole for it it move with the eccentric. Replace bolts, follow directions
Old Jun 21, 2016 | 10:51 PM
i8acobra's Avatar
i8acobra
If you didn't elongate the holes with die grinder, you didn't follow the directions. Toe bolts are cheap. Order a new set and follow the directions this time.
Old Jun 22, 2016 | 12:28 PM
canadarob's Avatar
canadarob
Looks like you may have stripped the subframe tabs which meet the toe bolt washer. Eitherway, trim the subframe hole as required + hope and pray it doesnt slip.
HipHop615
Suspension
Jul 8, 2016 01:48 PM
Haptic
Suspension
Apr 27, 2016 05:40 AM
NecktieNinja
Apr 26, 2016 06:57 PM
RobPhoboS
Apr 12, 2016 01:32 AM
