Front Strut stuck on transverse link
Old Oct 30, 2016 | 01:21 PM
NecktieNinja's Avatar
NecktieNinja
Default Front Strut stuck on transverse link
Hey guys, so im installing some mew Stance coils i just bought, but while i was removig my Teins out of my front right, the strut is literally stuck. Its stuck on the transverse link(i think thats what its called?). I have tomhe three screws holding the strut in at the too unscrewed, as well as pretty everything else. Idk why its giving me a hard time. It should just get super loose and be easy to take out like the left side i did before this. Anyone know whats going on? Would really appreciate it. Heres some pictures to help
Old Oct 30, 2016 | 01:24 PM
travlee's Avatar
travlee
Master
just take off the bolts holding the lower control arm in... then whack it with a dead blow hammer
Old Oct 30, 2016 | 02:07 PM
NecktieNinja
Sounds like thats work. Gonna go buy a wrench that fits that cuz the ones im using rn is way too thick and wont fit between
Old Oct 30, 2016 | 02:17 PM
travlee's Avatar
travlee
Master
its just 3 bolts
Old Oct 30, 2016 | 02:49 PM
Bak3rme's Avatar
Bak3rme
just look at the suspension picture you posted for 1 minute.
Its all like a puzzle and common sense.
Its a Coilover, so you can adjust the height of the strut. maybe making it shorter will give u space to take it out?
If not then just take off the end link...then take off the bolt thats attached to the subframe. if u can take that off then u can lower the LCA and remove ur strut.
u getting beat by very basic troubleshooting dawg.
Old Oct 30, 2016 | 02:52 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
First unscrew your coil adjuster all the way down, then you should be good to go.. If not grab a long piece of wood wedge it in a spot to take pressure off the suspension and pull it out.
Old Oct 30, 2016 | 02:56 PM
dboyzalter's Avatar
dboyzalter
Your also fighting with your sway bar, just disconnecting the end link would also solve your issue.
