Adjustable Front Upper Control Arms Hitting Wheel Well
Old Jan 3, 2018 | 06:08 PM
BlueSQ's Avatar
BlueSQ
Default Adjustable Front Upper Control Arms Hitting Wheel Well
I'm curious how many of you have experienced your aftermarket front upper control arms hitting the wheel well after having them installed. I read a post by rotchcrocket04 saying the SPC arms were banging against the wheel well on a suspension lowered only by 1". It's an older post so maybe they have this worked out these days.
Anyone else experiencing the same issue? If so, what brand FUCA are you using and what kind of a setup are you running?
Old Jan 4, 2018 | 08:39 PM
terrasmak's Avatar
I’m going to bet you have coilovers
Old Feb 1, 2018 | 12:29 PM
stascom's Avatar
stascom
In my case, Kinetix front A-arm's adjustability was limited by the wheel well. I had to take a mallet to the sheet metal inside and make some room. Got enough for up to +1pos camber. The rubber boot touches metal on compression but no noise.
Old Feb 7, 2018 | 04:28 PM
BlueSQ's Avatar
BlueSQ
I have Bilstein B8's and Eibach springs. I'm trying to set the front camber correctly so it's not feathering the front tires. When I did the forum research I saw that the aftermarket adjustable front upper control arms people were getting were hitting the wheel well but not too many people elaborated on it. My car is about 1" lower than stock.
Old Jan 30, 2023 | 08:07 AM
Geo_'s Avatar
Geo_
yeah bro to anyone reading this, if you dont fix it it'll screw up your frame a bit...not fun, took about 1 year for it to get bad, got bad since I thought it was normal, Ik im an idiot
venture210
Suspension
May 3, 2017 06:34 PM
power2rice
Suspension
Aug 13, 2013 07:58 PM
TripleD
Suspension
Aug 1, 2013 11:22 AM
spatcha
Jul 9, 2013 09:42 PM
jeeriko
Texas Marketplace
Feb 21, 2011 09:43 AM
