View Poll Results: Which offers the best performance?
Cusco
27.27%
Stillen
6.82%
Eibach
2.27%
Hotchkis
19
43.18%
Just keep it stock...
0%
350EVO
20.45%
Voters: 44. You may not vote on this poll
Sway Bars VOTE
I'll cast a vote for Hotchkis.
Pros: They work and work very well
Light weight (Hollow)
The fit and finish is perfect
Great Price
3 way adjustable on each end.
Cons: Um....er...uh....Cant think of any.
Great Price
I have the EVO swaybars. A drawback of the rear bar is you're losing nearly two inches of ground clearance in the rear; this is a bad thing for obvious reasons. It also looks bad when viewing the car from the rear, in my opinion. I would also avoid the EVO bushings if you don't like noise.
We have been working on the bushings. As far as clearance....I havent heard of this being an issue. Yes we do things a little different ...We are performance oriented in that sense and are always looking on ways to improve.
Great Price
Great Price
JICs, with the hots all loose up front, and all tight in the back... Yup, my Z has turnin like a Miata!
Well, I bought the Hotchkis bars. The only think that I would change is the ability to make them a little stiffer in the front. I would prefer to be able to go up to about 90% stiffer front instead of the max of 58% stiffer. Also, the softest in the rear is 64% and I don't plan on tightening up the rear much more since I can't tighten up the front. I don't want the rear end sliding out all the over the place with the rear at the max of 114% and the front at only 58% stiffer!!!!
I just dont get some of the numbers that are thrown out there.
Correct me if I am wrong but isnt the Hotckis bar 15/16th hollow.....and also does it follow the same bends that the OEM bar has?
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
