Possible brake booster failure
Old Jun 24, 2018 | 10:39 AM
TT03Z's Avatar
TT03Z
Default Possible brake booster failure
Hey guys wondering if anyone has had problems with their brake booster on a 03 350Z. A little back ground on the car and what I've tried so far. Car is twin turbo and makes a bunch of power 600+ mustang dyno at the moment. So the other day I was out with some friends doing pulls and digs. Ive noticed a few times before that the pedal gets very stiff but it usually goes away. This night however breaking was poor and it refused to do a burnout I was standing on the brake pedal trying to get the car to heat the tires up and it wouldn't hold. I've checked the check valves in the lines to the booster with shop air and they are doing their job. Holds pressure one way and free flows in the other direction. And i pulled the line off at the booster to make sure vacuum was making it's way there. Im pretty confident this has nothing to do with brake fluid at the moment I'm just wondering if anyone else has had to replace a booster on a FI application?
Old Jun 24, 2018 | 08:59 PM
bealljk's Avatar
bealljk
No issues on mine (been FI for ~35k miles ~ 10years) but I'm not nearly at your power levels either.
I think it'd be good measure and proactive to bleed the brakes and see what comes out...
Old Jun 25, 2018 | 11:22 AM
zakmartin's Avatar
zakmartin
Have you checked how much vacuum you're getting at the booster with a vacuum gauge?
speedk1ng
Exterior
Jun 22, 2018 06:43 AM
