JIC Coilovers ? again
Old Mar 30, 2004 | 05:56 PM
MCopare's Avatar
MCopare
Default JIC Coilovers ? again
need a place in Maryland to install JIC coilovers. how much should it cost me? or should i have dealership put them on? or do it myself? any comments or suggestions are greatly appreciated.
Old Mar 30, 2004 | 06:00 PM
Ultimateone's Avatar
Ultimateone
Do it yourself...its not that bad at all.
Old Mar 30, 2004 | 06:05 PM
MCopare's Avatar
MCopare
I do have access to a lift and the tools...just wondering about the whole cornerweighting thing.
Old Mar 30, 2004 | 07:47 PM
John's Avatar
John
I'd do it for you if I had time, but I really don't. All you really need is jackstands, a spring compressor (which you can rent at AutoZone), 17mm wrench, 17mm socket, 14mm socket, 12mm socket, and a drill. This is all off the top of my head, so it's possible I missed something minor...
Old Mar 30, 2004 | 09:50 PM
krisG35's Avatar
krisG35
You probably won't need the compressor if you're installing coilovers. The compressor is used to take the stock spring off the strut assembly. In this case you're just replacing the entire thing. Save yourself a couple bills and do it yourself! You'll be more satisfied when you're done.
Good luck!
Old Mar 31, 2004 | 04:32 AM
John's Avatar
John
You can avoid using the compressor if you take apart the rest of the suspension in order to leverage the OEM assembly out. It's easier to use the compressor though... plus the you were reimbursed the entire rental fee of $50 at AutoZone when you return it...
Stevo Z
Oct 3, 2015 09:14 PM
