Creaking with NISMO or other suspension?
Old Apr 18, 2004 | 07:05 PM
scubasteve's Avatar
scubasteve
Default Creaking with NISMO or other suspension?
I have had my S-Tune suspension in for a few months now....only driven it for about 3 weeks, and I have a noticable creaking noise when I move the car from a stop. Does anyone have this issue witht he S-Tune or other aftermarket suspension? I'm taking it back to the dealer, as the S-tune is covered under warranty and they said that they will correct any problem and cover it under warranty.......but I'm curious to what the problem is?
Old Apr 19, 2004 | 03:46 PM
ZxRage's Avatar
ZxRage
I had creaking when I installed my tein flex and cusco sway bars. I also replace the rods in the rear and the front a-arms. But when it was all put back together I had some loud creaking noises. I think it is the bushings. They need to be greased or lubed up. I also noticed that after driving my car for a while, they tend to warm up and stop making the noises. Anyone else have this problem?
Old Apr 19, 2004 | 06:33 PM
scubasteve's Avatar
scubasteve
I think that the noise comes from my brakes......track brembos. I'll have the daeler look at this issue. I'm now developing a rattling with my windows like they are loose or something.
Old Apr 19, 2004 | 07:21 PM
Rob Nance's Avatar
Rob Nance
I have the creaking with stock suspension and non-brembo brakes on my car. I had the sound before and after my new wheels. It is annoying, been having different people listen to it to see what they think. Some have said brakes, some have said suspension. Most all think it's probably normal, but nobody really knows. I wish I knew. I don't mind weird sounds if they are normal, I just don't want to be ignoring a problem, or something that could potentially be replaced for free under warranty.
Old Apr 19, 2004 | 07:39 PM
Judge's Avatar
Judge
I have paid attention to several posts about suspension noise. It seems hard to avoid. The only real solutions I've read about so far is teflon tape and marine grease. If that doesn't fix the noise, assuming it is the bushings, 350EVO is supposed to have a new squeak free bushing set.
Old Apr 20, 2004 | 08:52 AM
zturtle's Avatar
zturtle
any poly type bushings will stop the noise - and transmit a lot more general road noise.
Old Apr 20, 2004 | 12:22 PM
speedform's Avatar
speedform
Same issue running on Eibach sways and springs. I'm also pretty sure it's the bushings. I tried spraying them with WD-40 as a temp. fix just to check but they still made noise after the lube worked it's way in. Stubborn little buggers.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
