Camber kits for all 4 wheels
Old Apr 22, 2004 | 02:47 PM
zland's Avatar
zland
Sport Z Magazine
Default Camber kits for all 4 wheels
I rememeber a number of people were concerned about their car being within spec on camber after lowering their 350Z beyond 3/4".
Stillen is posting they are selling camber kits for all 4 wheels for 350Z's and G35's for $749 for the month of May. I thought some of you might not be aware of it.
I am not saying you should buy it or not, just letting you know about the option. You can decide if it is worth it or not. It's your tires....
Jeff - zland
Old Apr 22, 2004 | 02:48 PM
zland's Avatar
zland
Sport Z Magazine
Here is a pick for you to check out.
Old Apr 22, 2004 | 02:57 PM
NismoGCoupe's Avatar
NismoGCoupe
i didnt know stillen even made front A-arms
Old Apr 22, 2004 | 03:07 PM
trackstar's Avatar
trackstar
Goddamn Stillen is the biggest rip off ever. I hope their resellers have a better price, because (just like the Z32) they may be our only reliable option for quite some time.
Old Apr 22, 2004 | 05:08 PM
rodH's Avatar
rodH
wow, what a rip
Old Apr 22, 2004 | 07:45 PM
zland's Avatar
zland
Sport Z Magazine
I think it is expensive too. the problem is i have seen front and rear kits seperate for about $400 each thus not cheaper. Has anyone found a better deal?
Old Apr 22, 2004 | 08:38 PM
tig488's Avatar
tig488
uh, isnt that just rear camber arms and rear toe arms, nothing remotely close to that could adjust the front, must be a mistake?
Old Apr 22, 2004 | 09:20 PM
zland's Avatar
zland
Sport Z Magazine
You are right! Check out the link....
http://www.stillen.com/sportscars_pr...Filter=&Brand=
Old Apr 22, 2004 | 10:20 PM
350ed's Avatar
350ed
Professional
Kinetix is the only inexpensive game in town.
http://www.kinetixracing.com/index.a...WPROD&ProdID=8
$749 for front and rear package.
Old Apr 23, 2004 | 07:19 AM
zland's Avatar
zland
Sport Z Magazine
Thanks for the link and post.
Jeff - zland
Old Apr 23, 2004 | 10:38 AM
aaaaa's Avatar
aaaaa
will i need camber arms with eibach spring? (oem 18"rims?)
Old Apr 23, 2004 | 10:45 AM
zland's Avatar
zland
Sport Z Magazine
I have B&G springs which lower my 350Z 1" which is close to the drop your Eibacks provided. After getting a 4 wheel alignment, I was negative 1/2 degree off in camber. They feel I will lose about 10% of my tire life due to this. The positive is negative camber improves handling.
You need to decide if you want a little more tire wear or improved handing, then you have the answer to your question.
Jeff - zland
Old Apr 23, 2004 | 12:10 PM
speedform's Avatar
speedform
Same condition as above, although my rear doesn't seem to have been affected (Eibach springs). The fronts are wearing a little faster but is still acceptable in my opinion.
Old Apr 23, 2004 | 01:26 PM
trackstar's Avatar
trackstar
Based on the response to feathering, I think the general consensus leans towards longer tire life
Just kidding...mostly. I have read some opinions that feathering is a result of the aggressive suspension geometry which gives the car such great balance...regardless, it shouldn't have to be that way...oh well...
Old Dec 8, 2004 | 11:18 PM
jchen1020's Avatar
jchen1020
To add to that. I think rotating tires could be a good alt solution to cambers also. I am getting B&G, and will get front cambers. Rear links are adjutable. Optional may not be needed. if you do not mind
Old Dec 10, 2004 | 11:58 AM
prozac777's Avatar
prozac777
My Nissan dealership told me not to rotate the tires.........
Old Dec 14, 2004 | 07:48 AM
Driven's Avatar
Driven
Yeah...my Nissan dealership said to never change my oil either! They did, however, top off the blinker fluid when it was in.
Old Dec 14, 2004 | 11:58 AM
mojo powered's Avatar
mojo powered
bhahahaha.. that made my day.. good one!
Old Dec 14, 2004 | 04:26 PM
Rayden2001's Avatar
Rayden2001
I have the stillen kit and it doesn't really get my wheels where it should be....and still trying to fix this problem. Go here.
https://my350z.com/forum/showthread....ght=bad+camber
Old Dec 15, 2004 | 02:21 PM
jchen1020's Avatar
jchen1020
Here is the Alignment Final Numbers.
Bilstein Shocks with B&G Springs. Nice set up
Camber 1.3 left 1.4 right - (Front)
Caster 7.9 left 7.8 right - (Front)
Toe 0.5 left 0.5 right - (Front)
Camber 2.1 left 2.1 right - (rear)
Toe 1.1 left 1.2 rigth - (rear)
You really do not need camber kit if you use this set up. lowers exactly 1", these adjustment are maxed out as it sits. But they are with in Min of Factory Specs, or just barely crossed it. Tires should not have abnormal wear. Of course, again My Michelins are great, they lasted 38000 miles and still has 50 % tread. So we will see what brings next ....
Thank you all, hope this info help you guys out
