Does the 350z have camber adjustment?
Old May 1, 2004 | 10:46 PM
Nominee's Avatar
Nominee
Default Does the 350z have camber adjustment?
After lowering the 350z with springs only, is there camber and caster adjustment? Or do you have to purchase an aftermarket camber kit?
Thanks all.
Old May 1, 2004 | 10:50 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
CAMBER Adjustment Products
There is adjustment but it is soo slight... If you want to adjust your lowered suspension to eithe stock spec or even more positive or negitive camber angles you would need to make for some aftermarket parts...
we make front upper control arms and other company's make rear camber and toe for the rear..
I am going to be anouncing a front and rear camber alignment camber package special on monday...
Old May 1, 2004 | 10:53 PM
Legg350's Avatar
Legg350
stock-Front has no camber ajustment's-rear does but wont go back to spec after about 1" drop..You can get the rear close though. Tow can be ajusted front and rear
Old May 2, 2004 | 10:18 AM
Road Warrior's Avatar
Road Warrior
take a look at kinetix racing....you can get front and rear for cheaper kinetix
Old May 2, 2004 | 11:19 AM
Nominee's Avatar
Nominee
Default Thanks!
Thanks all, for your quick responses and knowledge.
