SPC Camber Arm?
Old May 26, 2004 | 01:19 PM
al503's Avatar
al503
Question SPC Camber Arm?
Any thoughts on this camber/toe? arm?
http://iapdirect.com/item.asp?invid=622
If you can adjust both the camber and toe with just one arm, this would seem the way to go for the $.
Old May 26, 2004 | 01:57 PM
Road Warrior's Avatar
Road Warrior
sounds like you have to elongate the OEM toe slots (rotary file) to get these to work...don't know if i care for that...but the price is reasonable
Gsedan35's Avatar
Gsedan35
The kit use's a adjustable arm to adjust camber, just like the other rear camber correction kits. It adjust's toe at the proper oem location by including with the camber arm a bolt that will adjust for more toe control then oem toe bolt cam will.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
