Will I need a camber kit?
Old May 28, 2004 | 07:58 AM
greddyZ's Avatar
greddyZ
Question Will I need a camber kit?
Experienced Z slammers, I need some advice.
I am going to put CUSCO Zero-1 Coilovers and Front/Rear sway bars on my car soon. I plan to lower the car only 1" front and rear. With this level of lowering, will I have significant camber problems in the front and rear? Will I need a full camber kit like what Kinetix Racing is offering? Please let me know.
Oh, my wheel/tire choice is as follows if this provides additional info:
19X9.5 F - 245/35ZR19s (Volk SF Challenge - Bridgestone S-03s)
19X10.5 R - 275/30ZR19s (Volk SF Challenge - Bridgestone S-03s)
Also, anyone with CUSCO coilovers want to comment on the ride/ handling.
Old May 28, 2004 | 08:11 AM
zwindsor's Avatar
zwindsor
Twisty addict
Have the alignment checked after a couple of hundred miles and see what happens. I believe the max drop is no more then 3/4" before you can't align without add-ons. Most likely you will need to get the camber kits unless you like negative camber for racing.
Old May 28, 2004 | 08:26 AM
greddyZ's Avatar
greddyZ
Thanks for the quick reply zwindsor! By the way...nice avatar! She's hot!
Well, I do like better handling and with the combination of lower ride height, sway bars, and wide rubber...I think that my ride will far exceed my ability to push it to the limit even on a race track. My main concern is tire wear. I want to get the car back to stock alignment specs. I know the tires will wear quick even at spec due to the "feathering" problem everyone is reporting but any delay in this to replace hyper expensive 19s is greatly appreciated if you follow my drift!
Old May 28, 2004 | 09:15 AM
Road Warrior's Avatar
Road Warrior
any lower than .8 inches and you will not be able to align to specs...posted up in this forum in one of those FAQ stuff...rw...out
Old May 28, 2004 | 09:30 AM
greddyZ's Avatar
greddyZ
Thanks Road Warrior! I did do a search before I asked and came up with nothing that was concrete in its answer. That is why I asked. Just to make sure.
Old May 28, 2004 | 09:50 AM
Road Warrior
glad i could help...here is the link if you want to verify link ...rw...out
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
