Do spacers alter alignment?
Old Jul 29, 2004 | 01:50 PM
kcobean's Avatar
kcobean
Default Do spacers alter alignment?
I'm scheduled to have my car aligned tomorrow after installing the Eibach springs last weekend.
I was wondering, if I decide to put some spacers on my car to widen its' stance a little, is that going to change the toe/camber of the car? I'm guessing caster will not be affected since the change is on the axis of the axle, and I guess in theory, toe and camber shouldn't change, but I thought I'd ask.
Any thoughts?
Old Jul 29, 2004 | 05:38 PM
myz8a4re's Avatar
myz8a4re
no, if you add spacers you will not affect your alignment. it would be the same as adding heavier offset wheels, your just changing the center line of your wheels. im sure youll be staying within 20mm or less right? best of luck!
-justin
Depravity
Oct 1, 2015 04:49 PM
FromGtoZ
Sep 20, 2015 03:41 PM
