Work wheels fitment with brembos
Does anyone know if the WORK REZAX 2 DDC wheels in 18x8 18x9 with a 33mm offset fit a g35 couple with brembos?
Thanks for your help
rmcole1@ev1.net
rmcole1@ev1.net
Rezax II come in half size widths from 17" to 20" diameter. They are available in ANY offset, they are ground to any offset. As far as brake clearance goes, they come in 3 discs - high, med, and lo. OE brembo fronts will require a high pad, OE brembo rears will require a medium pad.
Can't you go with a more aggressive offset for a g35 coupe, as well as wider wheels?
DDC lip is no longer available, I don't think.
[Hey there,
Thanks for the reply. They are preowned from a online dealer at a good price so that's why I was looking into the purchase. They would be hard to return if do not fit.
I have contacted the dealer and ask him to check the serial numbers of the wheels to see if it shows the discs that are on them. Thanks for the info
