Rust Proofing
Old Jan 21, 2003 | 05:49 PM
glkracer's Avatar
glkracer
Question Rust Proofing
I just got my Z and was wondering if I should rust proof it. Has anyone else felt this was necessary to do?
Old Jan 21, 2003 | 07:28 PM
krinkov's Avatar
krinkov
dont do it.
Your Z comes from the factory with rust proofing, and you have a factory warranty specificaly for rust. Rust proofing is a dealer installed scam along the lines of $600 paint sealant that can actually void your factory rust warranty!
Old Jan 22, 2003 | 04:25 AM
AndyB's Avatar
AndyB
Default Do NOT apply aftermarket undercoating/rustproofing.
This is serious. Do not EVER get after market or dealer sprayed undercoating.
The factory "system" includes various weap holes to allow water to escape. When companies spray undercoating they innevitably block some of these holes and cause problems.
This has been covered in consumer reports and in other magazines as well. Nobody (who is not trying to sell you something) recommends aftermarket undercoating because it can actually do harm.
The factory rustproofing is pretty darned awesome these days. I don;t see any reason to spend the money even if it didn't cause harm.
If it is sound reduction you seek, then perhaps you should look at interior apllied products like dynamat. They can reduce cabin sound and they don't cause other problems if applied properly.
Just my $.02 of course.
AndyB
Old Jan 22, 2003 | 04:30 AM
AndyB's Avatar
AndyB
Default PS: Undercoating
Two more thoughts on the topic.
Undercoating can void some factory rust warrantees. Check that first.
Undercoating can add a lot of weight to the car and slow it down. If you want every last bit of performance you don't want to add lots of weight.
Old Jan 22, 2003 | 07:43 AM
Kevin Overall's Avatar
Kevin Overall
Dont do it, I would also think that most of the under side parts of the new Z are alum. anyway.
Old Jan 22, 2003 | 03:18 PM
glkracer's Avatar
glkracer
Thanks gents for the advice. Since I am not going to run it in the salt, I probably wouldn't need it anyway!
Old Jan 28, 2003 | 04:17 PM
redheadscorp's Avatar
redheadscorp
Unhappy
Unfortunatly my friends i have officially found a rust spot o the underside of my 350Z. Tragic, now that it has shown its ugly face, how might i get rid of it? Is this covered under warrenty? A factory boo boo? Suggestions?
Old Jan 28, 2003 | 07:19 PM
joeshow750's Avatar
joeshow750
http://www.counteractrust.com/electronics%20methods.htm
This looks interesting.
Old Jan 30, 2003 | 07:39 PM
Black70Stang's Avatar
Black70Stang
Default well...
I wouldn't always believe what the dealers tell you as far as rust proofing goes... The fact is, it's almost impossible. As an experienced rust fixer, I've realized that rust can attack in so many ways that it's impossible to stop completely. In time, Rust will get to all metals that can harbor rust, and no matter what "rust proofer" you use, the result in time will be the same.
Ford offered a "rust proofing" feature on my car, as well. 32 years later?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
