Meguiars quick detail?????????????
Old Jan 28, 2007 | 11:57 AM
Zya123's Avatar
Zya123
Default Meguiars quick detail?????????????
I bought this quick detail spray( its in a red spray bottle) and i have a black Z, this stuff sucks, does anyone else have the same problam i do? it smears everywhere and it is soooooo hard to take off, what am i doing wrong? also when do u normally use this stuff?
Old Jan 28, 2007 | 12:41 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Are you sure you are not using "Wax as you Dry" product (also a maroon bottle)?
I don't have a black car but I have never had any problems with the detail spray on any of my cars (the dark burgundy Mini being the closest to black).
I use it for bugs and light dust, it is not a replacement for washing the car (although I do use it before I soap the car up to loosen gunk).
Chris
Old Jan 28, 2007 | 12:47 PM
Jay'Z's Avatar
Jay'Z
Chris
^^^ Great Idea.. I have this stuff just sitting.. never thought of it that way to loosen gunk.. thanks..
Old Jan 28, 2007 | 12:58 PM
igetgreens's Avatar
igetgreens
i use it after i wash my car when i don't wax it. it works great, maybe you are using it wrong or spraying too much. i use one side of the cloth to spread it and then another side to wipe it off
Old Jan 28, 2007 | 01:03 PM
Zya123's Avatar
Zya123
Like i washed the car and there was one spot that had water spots so i sprayed it on and thought it was all gone but if u look you can see its still smeary ,I dont know if im useing it wrong
Old Jan 28, 2007 | 01:05 PM
Jay'Z's Avatar
Jay'Z
Spray it on lightly.. let it dry.. then remove it with a clean clothe using a circular motion.. you will see it easily come off.....
Old Jan 29, 2007 | 12:04 AM
BlueDragonZ's Avatar
BlueDragonZ
If it's the quick detail spray then you don't really need to wait for it to dry. I usually just spray, use a towel to spread it around and another towel to finish it off.
Old Jan 29, 2007 | 12:22 AM
kukles's Avatar
kukles
Dirty towel? Ive never had an issue with quick detail...
Old Jan 29, 2007 | 07:33 AM
BMWWW's Avatar
BMWWW
You're in NY, so heat can't be the problem.
Meguiar's quick detail can be used both on paint and on plastics, so you can't be using the wrong product.
Perhaps give the sucker a good shake, and hope that the product has somehow seperated.
QD's are almost foolproof, so I'm **really** scratching my head on this one. Are you using a good micro-fiber to apply/remove, or some random rag?
Good luck!
--Gabe
Old Jan 29, 2007 | 07:41 AM
izmir41500's Avatar
izmir41500
Yea, I've had the same issue. It sucks and smears, etc... I thnk the directions say that if it smears, then you need to wax. Try the NXT quick detailer, worked the best for me. I've also tried turtle wax ice quick detailer, it works ok.
Old Jan 31, 2007 | 08:08 AM
Zya123's Avatar
Zya123
Im useing a micro fiber towel, I tried it again yesterday and same thing happend, smears everywhere and when you think you got it all off once it drys you see it and it still spreads, took about 40 min to clean the car with the stuff ahhh
Old Jan 31, 2007 | 09:12 AM
sq40's Avatar
sq40
I Only use it as a lubricant for the clay bar. The Stuff is not a replacement for waxing and to be honest, I don't really see the use for the stuff past being the clay-bar lube.
Old Jan 31, 2007 | 04:23 PM
MaximusZTS's Avatar
MaximusZTS
Its main use is to be a "the missing link between washes." Or something like that. It is used to remove light dust and fingerprints. So if you are at a car show you can use it to maintain your finish. It is a maintaince product.
Old Feb 1, 2007 | 05:55 AM
Zya123's Avatar
Zya123
Last night i took my car to the gym and parked under the light, when i got out i was like WTF, the whole car has streaks all over it because of that spray, now i have to go and re wax the car, damit
Old Feb 1, 2007 | 07:04 AM
dmroberson's Avatar
dmroberson
I've been using the Meguiar's Speed Detailer, in the purple bottle, and I've got no complaints yet.
Old Feb 1, 2007 | 07:09 AM
XtoZ's Avatar
XtoZ
ya i think we need to know if he is using the "quick detailer" or the "quick wax". quick detail should not smear at all, i use it all the time and i love it. quick wax would smear but it is a spray wax and it would need to dry the be buffed off......
Old Feb 1, 2007 | 08:13 AM
MaximusZTS's Avatar
MaximusZTS
Post a picture of the bottle!
Old Feb 1, 2007 | 09:15 AM
dmroberson's Avatar
dmroberson
I know the detail spray will leave streaks if it's not wiped off correctly. Even mine did that the first time I used it, til I learned to wipe it down completely.
Old Feb 1, 2007 | 02:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
everything is like that on a black car.
almost no product is streak free
you probably need to spray less at a time, and change towels more often.
Old Feb 1, 2007 | 02:57 PM
dedmoonstears's Avatar
dedmoonstears
Default is it cold..
you may be seeing the patterns from wiping
after a while even if it was initilally clear/clean if it cold enought the condensation would show/form on the wiping pattern
350Z_Al
Oct 29, 2020 07:44 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
