Cleaning volk rim lip
Hey guys I have a volk- GTC's for little over a year, and I have not been cleaning the front lip too hard to prevent from scratching (I only cleaned it with little pressure). Now I have brake dust build up on the lip which I can't remove now. Any mild product which could help move the dust? Thanks
you're completely f*ed at this point. The only way is to strip the adonizing off the lip of the wheels then hand polish the lip to a new shine. This will take at least 8 hours or more to do by hand as there is really no machine that can get into those small grooves. If you want you can have a shop take the wheels apart and polish the barrel but this will cost you $$$.
Once it is polished you will have to repolish by hand every month but this time it will be a lot easier.
I would probably use one or more of the following P21S products. The P21S Wheel Gel is safe on any wheel finish and is a great cleaner. The P21S Metal Polishing Soap also works great at cleaning and polishing at the same time. This may be a good product for your situation assuming your wheels are not anodized or painted surfaces (sorry I wasn't sure of the exact composition of the volk- GTC's). If you have deeply embedded stains, brake dust, etc. then I would use the P21S Finish Restorer. This metal polish is great for restoring a deep shine on virtually any metal or clear coated wheel. Let me know if you'd like more information about these products.
Greg @ Detailed Image
