NEW!!!! Daily Specials at Detailed Image
Old Dec 10, 2009 | 04:00 PM
  #541
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (December 10, 2009) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old Dec 11, 2009 | 12:28 PM
  #542
Detailed Image
Detailed Image
Today's Daily special (December 11, 2009) is Wheel Wax Wheel Wax.
Regular Price for 8 oz is $14.99. Today's price is $12.28!
  • Protects your wheels from stubborn contamination and brake dust build up
  • Easily maintain your protected wheels with automotive shampoo and water
  • Apply Wheel Wax to a clean wheel with a foam applicator pad in thin coats
  • Clean, restore and protect your wheels in one easy step
Old Dec 12, 2009 | 11:31 AM
  #543
Detailed Image
Detailed Image
Today's Daily special (December 12, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old Dec 13, 2009 | 07:35 AM
  #544
Detailed Image
Detailed Image
Today's Daily special (December 13, 2009) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.65!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old Dec 14, 2009 | 04:19 PM
  #545
Detailed Image
Detailed Image
Today's Daily special (December 14, 2009) is Poorboy's World Natty's Red Paste Wax.
Regular Price for 8 oz is $21.99. Today's price is $16.05!
  • One of the top performing carnauba waxes for under $25 and looks outstanding on any color
  • Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
  • Easy to apply and remove when applied properly, which is as thin as possible
  • An 8 oz jar will last dozens of applications when applied correctly
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old Dec 15, 2009 | 06:03 AM
  #546
Detailed Image
Detailed Image
Today's Daily special (December 15, 2009) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $26.99. Today's price is $20.70!
Regular Price for 128 oz is $74.99. Today's price is $59.70!
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Old Dec 16, 2009 | 11:26 AM
  #547
Detailed Image
Detailed Image
Today's Daily special (December 16, 2009) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.23!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Old Dec 17, 2009 | 11:31 AM
  #548
Detailed Image
Detailed Image
Today's Daily special (December 17, 2009) is Dodo Juice Banana Armour Hard Wax.
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on warmer colored vehicles
Old Dec 18, 2009 | 06:12 AM
  #549
Detailed Image
Detailed Image
Today's Daily special (December 18, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.83!
  • Designed to remove a majority of imperfections in the clear coat
  • Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old Dec 20, 2009 | 10:10 AM
  #550
Detailed Image
Detailed Image
Today's Daily special (December 20, 2009) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.13!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old Dec 21, 2009 | 05:53 AM
  #551
Detailed Image
Detailed Image
Today's Daily special (December 21, 2009) is Clear Kote Vanilla Moose Wax Hand Glaze.
  • Add additional gloss and depth to any color vehicle
  • Applies and removes easily by hand or when applied with a buffer
  • Shake product vigorously prior to use as the product will separate
  • Apply with a foam applicator pad and remove with a microfiber towel
Old Dec 29, 2009 | 08:00 AM
  #552
Detailed Image
Detailed Image
Today's Daily special (December 29, 2009) is Chemical Guys EXTREME V.R.T..
Regular Price for 16 oz is $8.99. Today's price is $6.47!
  • Very versatile dressing that restores vinyl, rubber and plastic to a clean, low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Extreme V.R.T.
  • To avoid over spray, we recommend misting Extreme V.R.T. into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Old Dec 30, 2009 | 06:34 AM
  #553
Detailed Image
Detailed Image
Today's Daily special (December 30, 2009) is Chemical Guys MetalWax - Ultra Fine Metal Polish & Protection.
Regular Price for 16 oz is $12.99. Today's price is $9.68!
  • Restore your metal surfaces to a brilliant shine and protect the finish all in one step
  • Ideal for polishing wheels, metal and chrome trim, interior metal trim and more
  • We recommend using a foam applicator pad for application
Old Dec 31, 2009 | 06:56 AM
  #554
Detailed Image
Detailed Image
Today's Daily special (December 31, 2009) is Glass Science Rain Clear.
Regular Price for 5 oz + Bonus is $5.99. Today's price is $4.54!
  • Sheet rain and water off of your glass when you have it protected with Rain Clear Gel
  • Help maximize your visibility when driving in bad weather conditions
  • For a streak free finish, try to apply as thin as possible to your glass, then buff clean
  • Includes a sample of Glass Science Glass Scrub
Old Jan 1, 2010 | 09:32 AM
  #555
Detailed Image
Detailed Image
Today's Daily special (January 1, 2009) is Chemical Guys Foam Pad Conditioner.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
  • Get the most out of polishing by keeping your pads fresh with the Foam Pad Conditioner
  • Simply give a quick mist to your buffing pad prior to applying your polish to the pad
  • Do not saturate your pad with product, only a mist is needed to prime the pad initially
Old Jan 2, 2010 | 09:07 AM
  #556
Detailed Image
Detailed Image
Today's Daily special (January 2, 2009) is Poorboy's World Spray Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.78!
Regular Price for 32 oz is $14.99. Today's price is $10.79!
Regular Price for 128 oz is $32.99. Today's price is $26.96!
  • Extremely versatile product that is a favorite amongst professional detailers
  • Quick and easy waterless wash product for lightly contaminated vehicles
  • Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Old Jan 3, 2010 | 12:15 PM
  #557
Detailed Image
Detailed Image
Today's Daily special (January 3, 2009) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.23!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • Properly preps your paints surface for sealing with the acrylic based glaze
  • When using a buffer, best applied with a black finishing pad
Old Jan 5, 2010 | 07:45 AM
  #558
Detailed Image
Detailed Image
Today's Daily special (January 5, 2010) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $5.03!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Old Jan 6, 2010 | 09:15 AM
  #559
Detailed Image
Detailed Image
Today's Daily special (January 6, 2010) is Dodo Juice Diamond White Hard Wax.
Old Jan 7, 2010 | 01:49 PM
  #560
Detailed Image
Detailed Image
Today's Daily special (January 7, 2010) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.19!
  • One of the best bang for the buck, pure sealants for under $20
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • When using a buffer, best applied with a blue fine finishing pad
