NEW!!!! Daily Specials at Detailed Image
Today's Daily special (April 4, 2010) is Chemical Guys Speed Wipe (Anti-Static) Quick Detailer.
Regular Price for 16 oz is $8.99. Today's price is $6.65!
- An outstanding quick detailer that is perfect to use after a maintenance wash and dry
- Leaves behind a slick surface that is anti-static which helps minimize dust build ups
- Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Today's Daily special (April 5, 2010) is Chemical Guys Synthetic Quick Detailer.
Regular Price for 16 oz is $9.99. Today's price is $7.19!
Regular Price for 128 oz is $27.99. Today's price is $24.13!
- A favorite quick detailer amongst professional detailers due to its outstanding shine and slickness
- Works great as a clay bar lubricant
- An ideal product to use after a wash to enhance the depth and gloss of your paint
- We recommend using a plush microfiber towel to apply the Synthetic Quick Detailers
Today's Daily special (April 6, 2010) is Lake Country & Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.06!
- Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
- Get optimal results with the 5.5" Lake Country foam and wool pads
- Allows you to easily put on new pads and pull of the old ones in just seconds
Today's Daily special (April 7, 2010) is Meguiar's Final Inspection M34.
Regular Price for 16oz is $7.99. Today's price is $5.75!
Regular Price for 128oz is $26.99. Today's price is $20.11!
- Great cleaning quick detailer to remove a light dusting, finger prints and light contamination safely
- Use after polishing to wipe down dust residue or after a sealant or wax to ensure there is no excess product left behind
- We recommend using M34 with an Ultra Plush Microfiber Towel
Today's Daily special (April 8, 2010) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
- Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
- Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
- Jet Seal 109 is one of the most popular sealants to apply with a blue pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (April 9, 2010) is Stoner Upholstery & Carpet Cleaner.
Regular Price for 18oz is $5.99. Today's price is $4.37!
- Powerful foaming formula that lifts dirt and stains from fabrics, carpets, mats and upholstery
- Works great on headliners as it evenly distributes product and dries quickly after wiping
- Does not leave behind a sticky film or residue
Today's Daily special (April 11, 2010) is Glass Science Rain Clear.
Regular Price for 5 oz + Bonus is $5.99. Today's price is $4.54!
- Sheet rain and water off of your glass when you have it protected with Rain Clear Gel
- Help maximize your visibility when driving in bad weather conditions
- For a streak free finish, try to apply as thin as possible to your glass, then buff clean
- Includes a sample of Glass Science Glass Scrub
Today's Daily special (April 14, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $17.99. Today's price is $13.40!
- Properly protect any wheel finish and minimize the amount of brake dust and road contamination
- Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
- One jar will last dozens of applications when applied correctly. The thinner the coat the better.
- Cleans, restores, protects and enhances gloss all in one simple step.
- Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
- Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (April 15, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 180 g is $18.99. Today's price is $13.48!
- Safely and effectively remove tar, sap, paint over spray and more
- Fine grade clay bars will not mar your finish when used properly
- We recommend using Dodo Juice Born Slippy as your clay lube
Today's Daily special (April 18, 2010) is Menzerna Intensive Polish (IP).
Regular Price for 32 oz is $25.99. Today's price is $20.00!
- A very popular medium cutting polish designed to remove moderate imperfections in the clear coat
- Can finish down hazy, so following up with a finishing polish is highly recommended
- Recommended application is using a buffer with an orange light cutting pad
- For accurate product dispensing, we recommend using a 4oz dispenser bottle
Today's Daily special (April 21, 2010) is Optimum (OPT) Protectant Plus.
Regular Price for 17 oz is $11.99. Today's price is $8.51!
Regular Price for 128 oz is $35.99. Today's price is $26.81!
- A versatile product that cleans and UV protects vinyl, rubber, leather, and plastic
- A perfect one step product to clean your interior dash and console
- To avoid over spray, we recommend misting Protectant Plus into a towel, then wiping the surface
Today's Daily special (April 22, 2010) is Poorboy's World Spray & Gloss (S&G).
Regular Price for 16 oz is $8.99. Today's price is $6.70!
Regular Price for 32 oz is $14.99. Today's price is $10.64!
- Commonly used after a wash to help enhance the gloss and depth, while extending the life of your protection
- Not only works well on paint, but glass, chrome and other areas of your vehicle
- Easy to apply and remove without streaking when applied correctly with a plush microfiber towel
- For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (April 23, 2010) is Dodo Juice Need for Speed Cleaner Wax.
Regular Price for 250 ml is $18.99. Today's price is $16.08!
- When time is of the essence, chemically clean your paint while leaving behind a coat of protection
- A great maintenance step when you want to start fresh without the need of a polishing session
- Top Need For Speed Cleaner Wax with your favorite carnauba wax for extended durability
- Can be applied with a foam applicator pad and removed with a quality microfiber towel
- When using a buffer, best applied with a black or blue finishing pad
Today's Daily special (April 25, 2010) is DI Accessories White Bucket with Handle.
Regular Price for 5 gallon is $9.99. Today's price is $7.44!
- Made out of durable high density polyethylene
- Plastic handle and tapered design
- Grit Guard Bucket Insert is highly recommended
Today's Daily special (April 27, 2010) is DI Accessories Medium Grade Clay Bar.
Regular Price for 180 g is $18.99. Today's price is $14.05!
- Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
- Large enough to break into several pieces for multiple uses
- We recommend Dodo Juice Born Slippy as a clay lube
- If you drop a piece of clay, throw it away!
Today's Daily special (April 28, 2010) is 303 High Tech Fabric Guard.
Regular Price for 16 oz is $14.99. Today's price is $10.94!
Regular Price for 32 oz is $26.99. Today's price is $19.97!
- Protects carpet, canvas and upholstery from staining by repelling liquids
- Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
- Works great on canvas convertible tops and outdoor patio furniture
- For maximum efficiency use in a 4oz pump spray bottle
Today's Daily special (April 29, 2010) is Meguiar's All Purpose Cleaner D101.
Regular Price for 128 oz is $13.99. Today's price is $9.93!
- Perfect for carpet, upholstery, vinyl and leather surfaces
- Concentrated formula works effectively at a 10:1 dilution ratio
- Agitate stubborn stains with a medium bristled brush for maximum results
- Exceptional value for detailers and enthusiasts
- Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (April 30, 2010) is Poorboy's World Natty's Blue Paste Wax.
Regular Price for 8 oz is $19.99. Today's price is $14.19!
- Arguably, the best carnauba paste wax for darker colored vehicles for under $20
- Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
- Easy to apply and remove with a foam applicator pad and a microfiber towel for removal
- An 8 oz jar will last dozens of applications when applied correctly
Today's Daily special (May 2, 2010) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
- A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
- Extremely easy to apply and remove, especially when applied in thin layers
- Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
- Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
- Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (May 5, 2010) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
- Bring out the maximum depth and gloss of any polish
- Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
- Experience longer work time and less dusting with less product absorption
